1426W-B
1426W-B
    HAMMONDMANUFACTURING
    BOX STEEL BLUE 10"L X 12"W
1426W-B 数据手册
8 7 6 5 4 254.00 mm [10.000 in] D 101.60 mm [4.000 in] 3 2 1 D 304.80 mm [12.000 in] 286.82 mm [11.292 in] 203.20 mm [8.000 in] 92.61 mm [3.646 in] A n5.54 mm [.218 in] 166.69 mm [6.563 in] n3.00 mm [.118 in] C C 57.95 mm [2.282 in] 230.19 mm [9.063 in] ASSEMBLY - SIDE VIEW EXPLODED ASSEMBLY - REAR VIEW EXPLODED 9.00 mm [.354 in] 288.94 mm [11.376 in] 3.18 mm [.125 in] 302.41 mm [11.906 in] n3.00 mm [.118 in] 12.70 mm [.500 in] 99.90 mm [3.933 in] 184.15 mm [7.250 in] 61.80 mm [2.433 in] 22.23 mm [.875 in] DETAIL A 217.49 mm [8.563 in] 177.80 mm [7.000 in] 21.03 mm [.828 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 6.35 mm [.250 in] n3.00 mm [.118 in] B 1.63 mm [.064 in] 281.79 mm [11.094 in] 12.70 mm [.500 in] 260.35 mm [10.250 in] B 1426W / 1426W-B 177.80 mm [7.000 in] 1426W - Case/Rear Panel Off W hite 1426W -B - Case/Rear Panel Satin Blue Screws / Feet 203.20 mm [8.000 in] 155.98 mm [6.141 in] 31.75 mm [1.250 in] 6.35 mm [.250 in] Screws 4 - 6-32 x 1/4 self tapping Feet 4 - Self Adhesive Rubber Feet Replacement Screws Replacement Rubber Feet 300.05 mm [11.813 in] 98.98 mm [3.897 in] 11.52 mm [.454 in] A 1.83 mm [.072 in] 8 7.53 mm [.296 in] n5.54 mm BOTTOM PANEL [.218 in] 7 254.00 mm [10.000 in] R3.18 mm [.125 in] 6 5.46 mm [.215 in] A FRONT PANEL (SATIN BLACK) 1426W/1426W-B 11.11 mm [.438 in] 5 4 1421J6 1421T9 3 2 1
1426W-B 价格&库存
很抱歉,暂时无法提供与“1426W-B”相匹配的价格&库存,您可以联系我们找货
1426W-B
    • 1+638.94098
    库存:1
