ROLEC-HAMMOND
WATERTIGHT (AluNORM)
Thick Wall Diecast Aluminum
(R101 Series)
Path: Home > Enclosure Index > ROLEC-HAMMOND Aluminum Product Index > Thick Wall >
R101 Series
Key Features:
z
z
z
z
z
z
z
z
z
z
z
Material - Aluminum die-cast: G AI SI 12 / DIN 1775
Deep lid, shallow body
Captive stainless steel lid screws
Neoprene oil and petrol resistant gasket standard. (-40ºC up to +80ºC)
Degree of protection NEMA 4X, IP66, DIN 40050
Temperature Range (-40ºC up to +80ºC)
Single-channel Fastening System. Trouble-free turning 90º to 90º with square enclosures by
synchronous arrangement of channels
Special developed external mounting feet made from zinc-die-cast. Can be turned through 90º.
The fastening holes have engagement lugs for this purpose. (See accessories)
All sizes have inner blind holes. A mounting plate made of zinc-plated steel is available (See
accessories)
Textured polyester powder coat, light grey RAL7032. (can be supplied unpainted on special
order)
CSA certified, Type 4, for use with industrial control equipment
Part No.
R101-080-000
R101-082-000
R101-084-000
R101-100-000
R101-102-000
R101-104-000
R101-120-000
R101-122-000
R101-124-000
R101-160-000
R101-162-000
R101-164-000
R101-166-000
R101-200-000
R101-202-000
R101-204-000
R101-240-000
R101-242-000
R101-244-000
R101-320-000
R101-322-000
Units
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
Width Length
A
80
3.2
80
3.2
80
3.2
100
4
100
4
100
4
120
4.8
120
4.8
120
4.8
160
6.4
160
6.4
160
6.4
160
6.4
200
8
200
8
200
8
240
9.6
240
9.6
240
9.6
320
12.8
320
12.8
B
80
3.2
120
4.8
160
6.4
100
4
150
6
200
8
120
4.8
180
7.2
240
9.6
160
6.4
240
9.6
320
12.8
480
19.2
200
8
300
12
400
16
240
9.6
360
14.4
480
19.2
320
12.8
480
19.2
Depth
(Including Lid)
C
60
2.4
60
2.4
60
2.4
80
3.2
80
3.2
80
3.2
100
4
100
4
100
4
100
4
100
4
100
4
100
4
120
4.8
120
4.8
120
4.8
120
4.8
120
4.8
120
4.8
120
4.8
120
4.8
R101-324-000
mm
inches
320
12.8
640
25.6
120
4.8
Features (by photo):
1 - Screws and mounting holes outside of gasket seal...
2 - Space saving single channel mounting (ie...same hole used for
mounting enclosure through rear and for the lid), provides larger
interior space than dual channel enclosures.
3 - Captive stainless steel lid screws...
4 - Enclosure holes threaded for easy installation and repetitive
assembly & disassembly...
5 - Internal mounting shelves placed along both sides of enclosure
include blind holes and grounding screws...
Exactly what you are looking for???
Link to our stocking distributors - most have "on-line" pricing, stock check
and ordering!!!
Order from your favorite distributor
Home | Products | Distributors | Technical | Contact Us | Other Options
Copyright; © 1999-2010 Hammond Mfg Co Inc
URL: http://www.hammondmfg.com
很抱歉,暂时无法提供与“R101-084-000”相匹配的价格&库存,您可以联系我们找货
