1590Z162GY
1590Z162GY
    HAMMONDMANUFACTURING
    BOX ALUM GRAY 10.24"L X 6.3"W
1590Z162GY 数据手册
240.00 [9.45] 82.30 [3.24] 260.00 [10.24] (INSIDE DEPTH) A 139.80 [5.50] B B 148.95 [5.86] (INSIDE WIDTH) 160.00 [6.30] A TOP VIEW 89.75 [3.53] 20.00 [.79] SECTION A-A END VIEW 2.10 [.08] 8.90 [.35] 4.40 [.17] (AVERAGE WALL THICKNESS) 217.50 [8.56] 71.85 [2.83] 240.00 [9.45] UL O C 146.00 [5.75] 139.80 [5.50] 85.00 [3.35] 248.83 [9.80] 220.27 [8.67] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. NOTE SECTION B-B SIDE VIEW ACCEPTS M6 MACHINE GROUND SCREW 215.00 [8.46] Purchased assembly includes box, lid, silicone gasket, 4 cover screws and 4 ground screws with washers. Box and lid are made from Diecast Aluminum Alloy. 246.00 [9.69] INSIDE LID C Recommended cover screw Torque 15-17 lbf.in ( 150 -170 cN.m) ACCEPTS M6 - 1 MACHINE SCREW 1590Z162 1590Z162 Enclosure Basic Enclosure Black Enclosure 109.80 [4.32] Grey Enclosure - RAL7001 Gloss 38.00 [1.50] 230.00 [9.06] DRAWINGS AVALIBLE FOR STEEL INNER PANEL 11.75 [.46] 151.27 [5.96] INSIDE BOX C 1590Z162 1590Z162BK 1590Z162GY ACCESSORIES 90.07 [3.55] 21.25 [.84] 240.00 [9.45] US LISTED (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) (INSIDE LENGTH) 251.27 [9.89] ® FILE #E65324 NEMA 4, 4X 18.75 [.74] Steel Inner Panel 1590Z162PL Pre-Formed Silicone Gasket Copper Ground Hardware (4 Pack) [M6 - 1.0 X 10mm / M6 Washer] 1590Z162G 7.23 SECTION C-C MOUNTING HOLE SCGM6 ® [.28] Dimensions: mm [inches] 1590Z162 www.hammondmfg.com
1590Z162GY 价格&库存
很抱歉,暂时无法提供与“1590Z162GY”相匹配的价格&库存,您可以联系我们找货
1590Z162GY
  • 1+801.63635
库存:3
