1590Z166BK
1590Z166BK
    HAMMONDMANUFACTURING
    BOX ALUM BLACK 14.17"L X 6.28"W
1590Z166BK 数据手册
360.00 [14.17] 82.00 [3.23] 340.00 [13.39] 4.00 [.16] (INSIDE DEPTH) A B B (AVERAGE WALL THICKNESS) 160.00 [6.30] 144.70 [5.70] 140.00 [5.51] (INSIDE WIDTH) 90.00 [3.54] A TOP VIEW 20.00 [.79] SECTION A-A END VIEW 360.00 [14.17] 315.00 [12.40] 2.00 [.08] 146.00 [5.75] 81.26 [3.20] 9.00 [.35] 317.69 [12.51] 345.01 [13.58] 5.50 SECTION B-B SIDE VIEW NOTE Purchased assembly includes box, lid, silicone gasket, 4 cover screws and 4 ground screws with washers. Box and lid are made from Diecast Aluminum Alloy. INSIDE LID Recommended cover screw Torque 15-17 lbf.in ( 150 -170 cN.m) 351.00 [13.82] 320.00 [12.60] C 1590Z166 ACCEPTS M6 - 1 MACHINE SCREW 1590Z166 Enclosure Basic Enclosure Black Enclosure 332.00 [13.07] 90.00 [3.54] 20.99 [.83] US LISTED (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 340.00 [13.39] [.22] ® FILE #E65324 NEMA 4, 4X Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 72.00 [2.83] (INSIDE LENGTH) UL O C 140.00 [5.51] ACCEPTS M6 MACHINE GROUND SCREW 351.00 [13.82] INSIDE BOX Grey Enclosure - RAL7001 Gloss 90.00 [3.54] 1590Z166 1590Z166BK 1590Z166GY ACCESSORIES 11.00 [.43] 151.00 [5.94] 38.00 [1.50] C DRAWINGS AVALIBLE FOR STEEL INNER PANEL 19.00 [.75] Steel Inner Panel 1590Z166PL Pre-Formed Silicone Gasket Copper Ground Hardware (4 Pack) [M6 - 1.0 X 10mm / M6 Washer] 1590Z166G SCGM6 6.60 [.26] SECTION C-C MOUNTING HOLE ® Dimensions: mm [inches] 1590Z166 www.hammondmfg.com
1590Z166BK
- 物料型号: 1590Z166 - 器件简介: 这是一个NEMA 4, 4X US LISTED的外壳,适用于需要保护内部组件免受灰尘、水和其他环境因素影响的应用。外壳由压铸铝合金制成,带有预成型的硅胶垫圈和铜接地硬件。 - 引脚分配: 文档中没有提供具体的引脚分配信息,但提到外壳接受M6 - 1.0 X 10mm的机器螺丝和M6接地螺丝。 - 参数特性: 外壳尺寸包括内部长度340.00mm [13.39英寸],内部宽度144.70mm [5.70英寸],内部深度82.00mm [3.23英寸],壁厚4.00mm [.16英寸]。外壳还包含一个M6机器螺丝的接地螺丝。 - 功能详解: 外壳设计用于提供保护,并且可以根据需要进行工厂修改,如铣削、钻孔、打印等。可以联系工厂获取报价和STEP或IGES格式的实体模型。 - 应用信息: 适用于需要NEMA 4, 4X等级保护的电子设备。 - 封装信息: 外壳和盖子由压铸铝合金制成,带有预成型的硅胶垫圈。购买的组装包括盒子、盖子、硅胶垫圈、4个盖子螺丝和4个带垫圈的接地螺丝。
1590Z166BK 价格&库存
很抱歉,暂时无法提供与“1590Z166BK”相匹配的价格&库存,您可以联系我们找货
1590Z166BK
  • 1+1300.043371+155.44205
  • 5+1111.270275+132.87105
  • 10+1067.9424010+127.69047
库存:9
