1452KE9
1452KE9
    HAMMONDMANUFACTURING
    BOX ALUM GRAY 8.99"L X 13.5"W
1452KE9 数据手册
8 7 32.26 mm [1.270 in] D 6 5 4 196.49 mm [7.736 in] 3 2 1 336.55 mm [13.250 in] 6.73 mm [0.265 in] D 323.09 mm [12.720 in] n6.35 mm 4X [0.250 in] B B 139.70 mm [5.500 in] 342.90 mm [13.500 in] 34.93 mm [1.375 in] END PANEL 228.75 mm [9.006 in] TOP OF ASSEMBLY C C 6.35 mm [0.250 in] 18.69 mm [0.736 in] A 22.24 mm [0.876 in] 22.23 mm [0.875 in] 125.40 mm [4.937 in] 215.90 mm [8.500 in] 3.18 mm [0.125 in] 15.88 mm [0.625 in] 19.05 mm [0.750 in] A 33.34 mm [1.313 in] n2.95 mm 4X [0.116 in] 195.78 mm [7.708 in] 19.02 mm [0.749 in] 25.78 mm [1.015 in] Note: END OF ASSEMBLY SIDE OF ASSEMBLY B 304.85 mm [12.002 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES Format. 210.15 mm [8.274 in] 32.13 mm [1.265 in] 13.18 mm [0.519 in] 11.11 mm [0.438 in] n5.97 mm 215.90 mm [8.500 in] 327.05 mm [12.876 in] [0.235 in] 3.18 mm [0.125 in] B 6.35 mm [0.250 in] 22.23 mm [0.875 in] 163.53 mm [6.438 in] 211.40 mm [8.323 in] 43.66 mm [1.719 in] A 44.07 mm [1.735 in] SECTION B-B INSIDE OF ASSEMBLY (VIEW OF SIDE) 66.51 mm [2.619 in] 50.80 mm [2.000 in] A 1452KE9 SECTION A-A INSIDE OF ASSEMBLY (VIEW OF BOTTOM) 8 7 6 5 4 3 2 1
1452KE9 价格&库存
很抱歉,暂时无法提供与“1452KE9”相匹配的价格&库存,您可以联系我们找货
1452KE9
  • 1+780.971351+101.33039
库存:10
1452KE9
  • 1+767.583271+99.59330
库存:10
1452KE9
