1590Z231GY
1590Z231GY
    HAMMONDMANUFACTURING
    BOX ALUM GRAY 7.87"L X 9.06"W
1590Z231GY 数据手册
180.00 [7.09] 200.00 [7.87] 101.50 [4.00] A (INSIDE DEPTH) 210.00 [8.27] B B 218.02 [8.58] (INSIDE WIDTH) 230.00 [9.06] A 20.00 [.79] 110.00 [4.33] TOP VIEW 2.10 [.08] 5.50 [.22] 4.50 [.18] (AVERAGE WALL THICKNESS) 9.00 [.35] SECTION A-A END VIEW 180.00 [7.09] 93.60 [3.69] UL O C 216.00 [8.50] 156.00 [6.14] 157.02 [6.18] 188.33 [7.41] 210.00 [8.27] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE SECTION B-B SIDE VIEW C US LISTED Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (INSIDE LENGTH) 191.07 [7.52] 160.07 [6.30] ® FILE #E65324 NEMA 4, 4X Purchased assembly includes box, lid, silicone gasket, 4 cover screws and 4 ground screws with washers. Box and lid are made from Diecast Aluminum Alloy. 155.00 [6.10] 185.74 Recommended cover screw Torque 15-17 lbf.in ( 150 -170 cN.m) [7.31] ACCEPTS M6 - 1 MACHINE SCREW INSIDE LID 1590Z231 1590Z231 Enclosure Basic Enclosure 21.34 [.84] 180.00 [7.09] Black Enclosure ACCEPTS M6 MACHINE GROUND SCREW 180.00 [7.09] Grey Enclosure - RAL7001 Gloss 160.07 [6.30] 170.50 [6.71] C INSIDE BOX 40.25 60.13 72.10 [1.58] [2.37] [2.84] 1590Z231 1590Z231BK 1590Z231GY ACCESSORIES 221.07 [8.70] 21.50 [.85] 14.00 [.55] Steel Inner Panel 1590Z231PL Pre-Formed Silicone Gasket Copper Ground Hardware (4 Pack) [M6 - 1.0 X 10mm / M6 Washer] 1590Z231G SCGM6 ® DRAWINGS AVALIBLE FOR STEEL INNER PANEL SECTION C-C MOUNTING HOLE 7.00 [.28] Dimensions: mm [inches] 1590Z231 www.hammondmfg.com
1590Z231GY 价格&库存
很抱歉,暂时无法提供与“1590Z231GY”相匹配的价格&库存,您可以联系我们找货
1590Z231GY
  • 1+1194.98781
库存:6
