1591BFBK
1591BFBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 4.41"L X 2.44"W
1591BFBK 数据手册
1591 Multi-purpose Enclosures Available with flanged lid or with a cemented bottom flange. Key Features • Ideally suited for vertical mounting of printed circuit boards (internal side walls include molded in card guides - see photo to the right). • Integral card guides accept 1.5 mm (0.062”) P.C. cards. • Lap joint construction provides protection against access of dust and splashing water. • Designed to meet IP54. • Standard versions are molded from easy to machine flame retardant ABS plastic which carries a UL flammability rating of 94V-0. • Economy versions are molded from general purpose (not flame-retardant) plastic. • On standard versions the lid is secured with M3 x 10 mm Philips machine screws, threaded into integral brass bushings. Perfect for applications when repetitive assembly and disassembly are required (see photo below to the right). • Economy versions are assembled with self tapping screws into fully plastic posts. • Black enclosures include black screws, all others - standard nickel finish screws. Alternatives • If EMI/ RFI Shielding is required, try “1591R” on page 49 • If card guides are not required or horizontal mounting of printed circuit boards is preferred, try “1591XX” on page 10 • For transparent polycarbonate verions, try “1591T” on page 15. www.hammondmfg.com All models have integral card guides. Shown here with brass bushings for machine screw assembly. USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 12 1591 Multi-purpose Enclosures Accessories 100-pack of replacement screws Flange Kits (see “1591” on page 16 ) 1591MS100BK (black) 1591MS100 (plated) Clear Lids 1591TS100 (plated) Belt Clip Kits 1591TS100BK (black) 1599CLIP (black) 1599CLIPGY (gray) Standard Economy Standard w/ Flanged Lid Economy w/ Flanged Lid Standard w/ Bottom Flange Economy w/ Bottom Flange 1591MBG 1591MBK 1591MSBK 1591MFLBK 1591MSFLBK 1591MF2BK 1591MF2SBK 1591MSGY 1591MFLGY 1591LSBK 1591LFLBK 1591MF2GY 1591MF2SGY Grey 1591LF2BK 1591LF2SBK Black Blue 1591LSGY 1591LFLGY 1591ASBK 1591AFLBK 1591LF2GY 1591LF2SGY 1591AF2BK 1591AF2SBK 1591ABG  1591ABK 1591ASGY 1591AFLGY 1591AF2GY 1591AF2SGY 1591SSBK 1591SFLBK 1591SSFLBK 1591SF2BK 1591SF2SBK 1591SSGY 1591SFLGY 1591SF2GY 1591SF2SGY Inches mm 3.3 85 2.2 56 0.8 21 1591LC Inches mm 3.3 85 2.2 56 1.4 35 1591LC Inches mm 3.9 100 2 50 0.8 21 1591AC Inches mm 4.3 110 3.2 82 1.6 40 1591SC Inches mm 4.4 112 2.4 62 1.1 27 1591BC Grey Black Grey Beige 1591BSBK 1591BFLBK 1591BSFLBK 1591BF2BK 1591BF2SBK 1591BBU 1591BGY Black Blue 1591BBG  1591BBK Clear Lid (no flange) Beige 1591SBU 1591SGY Depth (less lid) Grey Blue 1591SBG  1591SBK Width Beige 1591ASFLBK 1591ABU 1591AGY Length Beige 1591LSFLBK 1591LBU 1591LGY Black Blue 1591LBG  1591LBK Units Beige 1591MBU 1591MGY Color Black Blue 1591BSGY 1591BFLGY www.hammondmfg.com 1591BF2GY 1591BF2SGY Grey USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 13 1591 Standard Multi-purpose Enclosures Economy Standard w/ Flanged Lid Economy w/ Flanged Lid Standard w/ Bottom Flange Economy w/ Bottom Flange Color 1591CSBK 1591CFLBK 1591CSFLBK 1591CF2BK 1591CF2SBK Black 1591CBG  1591CBK Blue 1591CSGY 1591CFLGY 1591TSBK 1591TFLBK 1591CF2GY 1591CF2SGY Grey 1591TF2BK 1591TF2SBK Black 1591TBG  1591TBK Blue 1591TSGY 1591TFLGY 1591USBK 1591UFLBK 1591TF2GY 1591TF2SGY Grey 1591UF2BK 1591UF2SBK Black 1591UBG  1591UBK Blue 1591USGY 1591UFLGY 1591UF2GY 1591UF2SGY 1591VBG  1591VBK 1591VSBK 1591VFLBK 1591VSFLBK 1591VF2BK 1591VF2SBK 1591VSGY 1591VFLGY 1591GSBK 1591GFLBK 1591VF2SGY Grey 1591GF2BK 1591GF2SBK Black Blue 1591GSGY 1591GFLGY 1591DSBK 1591DFLBK 1591GF2GY 1591GF2SGY 1591DF2BK 1591DF2SBK 1591DSGY 1591DFLGY 1591HSBK 1591HFLBK 1591DF2SGY Grey 1591HF2BK 1591HF2SBK Black Blue 1591HSGY 1591HFLGY 1591HF2GY 1591HF2SGY Inches mm 4.7 120 3.2 80 2.2 55 1591TC Inches mm 4.7 120 4.7 120 2.2 55 1591UC Inches mm 4.7 120 4.7 120 3.5 90 1591VC Inches mm 4.8 121 3.7 94 1.2 30 1591GC Inches mm 5.9 150 3.2 80 1.8 46 1591DC Inches mm 6.5 165 2.8 71 1 25 1591HC Inches mm 7.5 191 4.3 110 2.2 57 1591EC Grey Beige 1591ESBK 1591EFLBK 1591ESFLBK 1591EF2BK 1591EF2SBK 1591EBU 1591EGY 1591CC Beige 1591HSFLBK 1591EBG  1591EBK Black 1591DF2GY 1591HBU 1591HGY 1.4 36 Grey Blue 1591HBG  1591HBK 2.6 65 Beige 1591DSFLBK 1591DBU 1591DGY 4.7 120 Beige 1591GSFLBK 1591DBG  1591DBK Black 1591VF2GY 1591GBU 1591GGY Inches mm Grey Blue 1591GBG  1591GBK Clear Lid (no flange) Beige 1591VBU 1591VGY Depth (less lid) Beige 1591USFLBK 1591UBU 1591UGY Width Beige 1591TSFLBK 1591TBU 1591TGY Length Beige 1591CBU 1591CGY Units Black Blue 1591ESGY 1591EFLGY www.hammondmfg.com 1591EF2GY 1591EF2SGY Grey USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 14
1591BFBK
1. 物料型号: - 标准版:1591MBG(米色)、1591MBK(黑色)、1591MBU(蓝色)、1591MGY(灰色) - 经济版:1591MSBK(黑色)、1591MSGY(灰色) - 带法兰盖的标准版:1591MFLBK(黑色)、1591MFLGY(灰色) - 带法兰盖的经济版:1591MSFLBK(黑色)、1591MSFLGY(灰色) - 带底部法兰的标准版:1591MF2BK(黑色)、1591MF2GY(灰色) - 带底部法兰的经济版:1591MF2SBK(黑色)、1591MF2SGY(灰色)
2. 器件简介: - 该产品为多用途的PCB封装盒,适用于垂直安装印刷电路板,内部侧壁包含模制的卡片导轨,可接受1.5毫米厚的PC卡。采用搭接构造,可防止灰尘和飞溅水的侵入,设计满足IP54防护等级。
3. 引脚分配: - 标准版盖子通过M3 x 10毫米的Philips机械螺丝固定,这些螺丝拧入内置的黄铜衬套中,适合需要频繁组装和拆卸的应用。 - 经济版则使用自攻螺丝固定在全塑料柱上。
4. 参数特性: - 标准版由易于机械加工的阻燃ABS塑料制成,UL阻燃等级为94V-0。 - 经济版由通用(非阻燃)塑料制成。
5. 功能详解: - 该产品具有EMI/RFI屏蔽需求时,可选用“1591R”型号。 - 如果不需要卡片导轨或更倾向于水平安装PCB,可选用“1591XX”型号。 - 对于透明聚碳酸酯版本,可选用“1591T”型号。
6. 应用信息: - 适用于需要重复组装和拆卸的应用场景,如工业控制、电子设备保护等。
7. 封装信息: - 提供了多种颜色选择,包括黑色、米色、蓝色和灰色。 - 尺寸和具体型号在文档中有详细列出,包括不同长度、宽度和深度的型号。
1591BFBK 价格&库存
很抱歉,暂时无法提供与“1591BFBK”相匹配的价格&库存,您可以联系我们找货
