112-040
112-040
    BIVAR
    TO-18
    MOUNT CIRCULAR TO18 0.040"
112-040 数据手册
REV. DESCRIPTION C D 0.100 [2.5mm] Engineering Update w/o Changes Removed Material Code TYP. DATE APPROVED 02/16/04 05/22/16 M. C. J. C. 0.040 [1.0mm] Ø.025 [Ø0.6mm] 0.020 [0.5mm] TYP. Ø.225 [Ø5.7mm] 0.100 [2.5mm] 0.155 [3.9mm] Ø.025 [Ø0.6mm] Ø.040 [Ø1.0mm] TYP. 0.125 [3.2mm] TYP. TYP. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 S. Irving M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-18 MOUNT DATE: 06/01/98 DATE: 06/25/02 PART NO: REVISION: 112-040 CAGE CODE : 32559 D SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
112-040 价格&库存
很抱歉,暂时无法提供与“112-040”相匹配的价格&库存,您可以联系我们找货
    库存:657
    112-040
    • 1+61.676061+7.97780
    • 10+24.7228410+3.19790
    • 100+22.27677100+2.88150
    • 500+19.74333500+2.55380
    • 1+63.09152
    • 10+25.25285
    • 100+22.81688
    • 500+20.21852
