118-055
118-055
    BIVAR
    TO-18
    MOUNT CIRCULAR TO18 0.055"
118-055 数据手册
REV. D E DESCRIPTION Engineering Update w/o Changes Removed Material Code DATE APPROVED 02/13/04 05/23/16 M. C. J. C. 0.040 [1.0mm] 0.100 [2.5mm] 0.020 [0.5mm] TYP. Ø.245 [Ø6.2mm] Ø.050 [Ø1.3mm] TYP. Ø.028 [Ø0.7mm] w/ Ø.050 C'SINK Far Side, TYP. 0.14 [3.4mm] TYP. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. ± .1 ± .01 ± .005 DESIGNED: S. Irving 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-18 MOUNT DATE: 06/15/98 DATE: 06/25/02 PART NO: REVISION: 118-055 CAGE CODE : 32559 E SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
118-055 价格&库存
很抱歉,暂时无法提供与“118-055”相匹配的价格&库存,您可以联系我们找货
  • 1+2.227291+0.28961
  • 1+61.354701+7.97780
  • 10+24.5940210+3.19790
  • 100+22.16069100+2.88150
  • 500+19.64046500+2.55380
库存:500
118-055
  • 1+62.72879
  • 10+25.15380
  • 100+22.66238
  • 500+20.08711
库存:500
