105-021
105-021
    BIVAR
    MOUNT CIRCULAR TO18 0.021"
105-021 数据手册
REV. DESCRIPTION A Engineering Update w/o Changes B Material Correction C Removed Material Code 0.100 [2.5mm] TYP. DATE APPROVED 02/13/04 08/05/04 05/23/16 M. C. M. C. J. C. 0.020 [0.5mm] Ø.250 [Ø6.4mm] Ø.028 [Ø0.7mm] w/ Ø.045 C'SINK Near Side, TYP. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. ± .1 ± .01 ± .005 DESIGNED: S. Irving CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-18 MOUNT DATE: 06/18/98 DATE: 02/13/04 PART NO: REVISION: 105-021 CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
105-021 价格&库存
很抱歉,暂时无法提供与“105-021”相匹配的价格&库存,您可以联系我们找货
    • 1+2.052401+0.26140
    • 10+1.6676010+0.21240
    • 100+1.53930100+0.19610
    • 500+1.29440500+0.16490
    • 1000+1.152201000+0.14670
    • 2500+1.067002500+0.13590
    • 5000+0.998205000+0.12710
    • 10000+0.9049010000+0.11530
    • 25000+0.8711025000+0.11090
    库存:8399
    105-021
    • 1+4.82713
    • 10+1.93564
    • 100+1.73921
    • 500+1.54396
    • 1+2.234101+0.28897
    • 10+1.9829010+0.25648
    • 25+1.8920425+0.24473
    • 50+1.8232050+0.23582
    • 100+1.75618100+0.22715
    • 250+1.67346250+0.21646
    • 500+1.61296500+0.20863
    • 1000+1.554671000+0.20109
    • 5000+1.427265000+0.18461
    库存:25930
    105-021
