121-032
121-032
    BIVAR
    TO-18
    MOUNT CIRCULAR TO18 0.032"
121-032 数据手册
REV. B C DESCRIPTION Engineering Update w/o Changes Removed Material Code 0.100 [2.5mm] TYP. DATE APPROVED 02/13/04 05/23/16 M. C. J. C. 0.032 [0.8mm] Ø.187 [Ø4.7mm] Ø.030 [Ø0.8mm] TYP. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. ± .1 ± .01 ± .005 DESIGNED: S. Irving 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-18 MOUNT DATE: 06/18/98 DATE: 07/23/02 PART NO: REVISION: 121-032 CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
121-032 价格&库存
很抱歉,暂时无法提供与“121-032”相匹配的价格&库存,您可以联系我们找货
