REV.
DESCRIPTION
A
B
C
D
0.052 [1.3mm]
DATE
Engineering Update w/o Changes
Added 425-150
Dimension Correction.
425-150 Material Color Update.
02/23/04
10/18/05
10/25/05
01/31/06
APPROVED
M. C.
M. C.
M. C.
M. C.
H REF.
0.220 [5.6mm]
0.14 [3.6mm]
F
TYP.
L
0.35 [8.8mm]
TYP.
0.425 [10.8mm]
0.125 [3.2mm]
Ø.060 [Ø1.5mm]
TYP.
PART NO.
423-125
423-150
423-175
423-200
424-125
424-150
424-175
424-200
425-150
H
.125 (3.2)
.150 (3.8)
.175 (4.4)
.200 (5.1)
.125 (3.2)
.150 (3.8)
.175 (4.4)
.200 (5.1)
.150 (3.8)
F
.000
.025 (.64)
.050 (1.3)
.075 (1.9)
.000
.025 (.64)
.050 (1.3)
.075 (1.9)
.025 (.64)
L
MATERIAL
.255 (6.5)
A
.280 (7.1)
B
.315 (8.0)
A
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
3. MATERIAL B: NYLON 6/6, 94V-2, WHITE. BIVAR MATERIAL CODE 04-WE.
BASF ULTRAMID NYLON 6/6 A3K WHITE.
2. MATERIAL A: NYLON 6/6, 94V-2, BLACK. BIVAR MATERIAL CODE 03-NL-BK.
BASF ULTRAMID NYLON 6/6 A3K NATURAL W/BLACK PIGMENT ADDED.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
DECIMALS
.X
.XX
± .1
± .01
.XXX
± .005
DESIGNED:
Michael Chen
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: MOLDED POWER
TRANSISTOR MOUNT (TO-202/220)
DATE:
PART NO:
03/10/03 423-XXX / 424-XXX / 425-XXX
DATE:
03/10/03
CAGE CODE : 32559
REVISION:
D
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“423-200”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.828711+0.49596
- 10+2.6203810+0.33943
- 100+1.86903100+0.24211
- 500+1.52748500+0.19787
- 1000+1.415001000+0.18330
- 2000+1.319142000+0.17088
- 5000+1.214175000+0.15728
- 10000+1.1486210000+0.14879
- 25000+1.0770425000+0.13952
