102-050
102-050
    BIVAR
    TO-18
    Component Mount TO-18 Circular 0.050" (1.28mm) White
102-050 数据手册
REV. B C 0.100 [2.5mm] TYP. 0.13 [3.4mm] TYP. DESCRIPTION Engineering Update w/o Changes Removed Material Code DATE APPROVED 02/13/04 05/22/16 M. C. J. C. H REF. T F F Ø.245 [Ø6.2mm] Ø.036 [Ø0.9mm] TYP. Ø.045 [Ø1.1mm] TYP. PART NO. 102-050 102-060 102-070 102-080 102-090 102-100 102-110 102-120 H .050 (1.3) .060 (1.5) .070 (1.8) .080 (2.0) .090 (2.3) .100 (2.5) .110 (2.8) .120 (3.0) T .030 (.76) .030 (.76) .030 (.76) .030 (.76) .030 (.76) .030 (.76) .030 (.76) .030 (.76) F .010 (.25) .015 (.38) .020 (.51) .025 (.64) .030 (.76) .035 (.89) .040 (1.0) .045 (1.1) PART NO. 102-130 102-140 102-150 102-160 102-170 102-180 102-190 102-200 H .130 (3.3) .140 (3.6) .150 (3.8) .160 (4.1) .170 (4.3) .180 (4.6) .190 (4.8) .200 (5.1) T .030 (.76) .030 (.76) .030 (.76) .030 (.76) .030 (.76) .030 (.76) .030 (.76) .030 (.76) F .050 (1.3) .055 (1.4) .060 (1.5) .065 (1.7) .070 (1.8) .075 (1.9) .080 (2.0) .085 (2.2) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 M. Chen D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 04/11/03 DATE: 04/11/03 PERM-O-PAD TO-18 MOUNT REVISION: PART NO: 102-XXX CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
102-050 价格&库存
很抱歉,暂时无法提供与“102-050”相匹配的价格&库存,您可以联系我们找货
