ECM-13
ECM-13
    BIVAR
    MOUNT CIRCULAR ELECT CAP 0.270"
ECM-13 数据手册
REVISIONS NOTES: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATIONS: BV00-E101. 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. REV. D E F G DESCRIPTION REMOVED P/N ECM-2 REMOVED P/N FROM PART OFFERING LIST REMOVED P/N FROM PART OFFERING LIST ECO-1119, RE-INSTATE ECM-1, REMOVE -4/-5 DATE APPROVED 07/16/14 J.C. J.C. J.C. A.V. 09/29/15 11/20/15 02/07/22 .270IN 6.9mm O.D. THRU-HOLE 4X .020IN 0.5mm FOOT DIA. I.D. .030IN 0.8mm PART NO. ECM-1 ECM-13 EC TYPE 5 35 I.D. .227 (5.8mm) 1.410 (35.8mm) O.D. .287 (7.3mm) 1.470 (37.3mm) THRU-HOLE .125 (3.2mm) .645 (16.4mm) FOOT DIA. .060 (1.5mm) .138 (3.5mm) CUSTOMER USE DRAWING  STANDARD TOLERANCE (UNLESS OTHERWISE SPECIFIED) DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: S.IRVING REVISED: A.VALDEZ CHECKED: E.CHAN ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: ELECTROLYTIC CAPACITOR MOUNT DATE: REVISION: DRAWING NO: ECM-XX 8/27/1998 G DATE: CAGE CODE: SHEET 2/7/2022 SIZE 32559 A DATE: 2/7/2022 SCALE: 1:1 SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
ECM-13 价格&库存
很抱歉,暂时无法提供与“ECM-13”相匹配的价格&库存,您可以联系我们找货
