511-038
511-038
    BIVAR
    TO-5
    MOUNT CIRCULAR TO5 0.040"
511-038 数据手册
REV. DESCRIPTION A Engineering Update w/o Changes B Material update to 03-NL C Removed Material Code DATE APPROVED 02/23/04 10/29/07 05/23/16 M. C. M. C. J. C. 0.200 [5.1mm] TYP. 0.020 [0.5mm] 0.040 [1.0mm] 0.28 [7.1mm] TYP. Ø.046 [Ø1.2mm] TYP. Ø.045 [Ø1.1mm] w/ Ø.060 C'SINK Far Side, TYP. 45° 60° Ø.345 [Ø8.8mm] TYP. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 S. Irving D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-5 MOUNT DATE: 09/23/98 DATE: 02/23/04 PART NO: REVISION: 511-038 CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
511-038 价格&库存
很抱歉,暂时无法提供与“511-038”相匹配的价格&库存,您可以联系我们找货
