424-150
424-150
    BIVAR
    TO-202
    MOUNT RECT TO202/220 0.150"
424-150 数据手册
REV. DESCRIPTION A Engineering Update w/o Changes B Added 425-150 C Dimension Correction D 425-150 Material Color Update E Removed Material Code 0.052 [1.3mm] DATE APPROVED 02/23/04 10/18/05 10/25/05 01/31/06 05/22/16 M. C. M. C. M. C. M. C. J. C. H REF. 0.220 [5.6mm] 0.14 [3.6mm] F TYP. L 0.35 [8.8mm] TYP. 0.425 [10.8mm] 0.125 [3.2mm] Ø.060 [Ø1.5mm] TYP. PART NO. 423-125 423-150 423-175 423-200 424-125 424-150 424-175 424-200 425-150 H .125 (3.2) .150 (3.8) .175 (4.4) .200 (5.1) .125 (3.2) .150 (3.8) .175 (4.4) .200 (5.1) .150 (3.8) F .000 .025 (.64) .050 (1.3) .075 (1.9) .000 .025 (.64) .050 (1.3) .075 (1.9) .025 (.64) L MATERIAL .255 (6.5) A .280 (7.1) B .315 (8.0) A STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 3. MATERIAL B: NYLON 6/6, 94V-2, WHITE. .X .XX .XXX 2. MATERIAL A: NYLON 6/6, 94V-2, BLACK. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 M. Chen D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 MOLDED POWER TITLE: TRANSISTOR MOUNT (TO-202/220) DATE: REVISION: PART NO: 03/10/03 423-XXX / 424-XXX / 425-XXX E DATE: 03/10/03 CAGE CODE : 32559 SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
424-150 价格&库存
很抱歉,暂时无法提供与“424-150”相匹配的价格&库存,您可以联系我们找货
    • 6+134.449236+17.39025
    • 10+103.4216610+13.37701
    • 25+79.5552125+10.29002
    库存:32
    424-150
      • 50+44.8512250+5.80125
      • 100+33.56820100+4.34186
      库存:247
      424-150
        库存:209
