REV.
DESCRIPTION
A Engineering Update w/o Changes
B Added 425-150
C Dimension Correction
D 425-150 Material Color Update
E Removed Material Code
0.052 [1.3mm]
DATE
APPROVED
02/23/04
10/18/05
10/25/05
01/31/06
05/22/16
M. C.
M. C.
M. C.
M. C.
J. C.
H REF.
0.220 [5.6mm]
0.14 [3.6mm]
F
TYP.
L
0.35 [8.8mm]
TYP.
0.425 [10.8mm]
0.125 [3.2mm]
Ø.060 [Ø1.5mm]
TYP.
PART NO.
423-125
423-150
423-175
423-200
424-125
424-150
424-175
424-200
425-150
H
.125 (3.2)
.150 (3.8)
.175 (4.4)
.200 (5.1)
.125 (3.2)
.150 (3.8)
.175 (4.4)
.200 (5.1)
.150 (3.8)
F
.000
.025 (.64)
.050 (1.3)
.075 (1.9)
.000
.025 (.64)
.050 (1.3)
.075 (1.9)
.025 (.64)
L
MATERIAL
.255 (6.5)
A
.280 (7.1)
B
.315 (8.0)
A
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
3. MATERIAL B: NYLON 6/6, 94V-2, WHITE.
.X
.XX
.XXX
2. MATERIAL A: NYLON 6/6, 94V-2, BLACK.
DESIGNED:
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
CHECKED:
± .1
± .01
± .005
M. Chen
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
MOLDED POWER
TITLE:
TRANSISTOR MOUNT (TO-202/220)
DATE:
REVISION:
PART NO:
03/10/03
423-XXX / 424-XXX / 425-XXX
E
DATE:
03/10/03
CAGE CODE : 32559
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“423-125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+86.26556
- 10+34.61642
- 100+31.13082
- 500+27.65720
