DESCRIPTION
REV.
B Engineering Update w/o Changes
C Removed Material Code
0.100 [2.5mm]
SQ.
H
0.200 [5.1mm]
TYP.
APPROVED
M. C.
J. C.
REF.
T
F
DATE
02/16/04
05/22/16
F
Ø.330 [Ø8.4mm]
Ø.025 [Ø0.6mm]
TYP.
Ø.070 [Ø1.8mm]
TYP.
0.16 [4.0mm]
TYP.
PART NO.
H
T
F
PART NO.
H
T
F
126-140
.140 (3.6)
.030(.76)
.055 (1.4)
.005 (.13)
126-150
.150 (3.8)
.030(.76)
.060 (1.5)
.030(.76)
.010 (.25)
126-160
.160 (4.1)
.030(.76)
.065 (1.7)
.060 (1.5)
.030(.76)
.015 (.38)
126-170
.170 (4.3)
.030(.76)
.070 (1.8)
126-070
.070 (1.8)
.030(.76)
.020 (.51)
126-180
.180 (4.6)
.030(.76)
.075 (1.9)
126-080
.080 (2.0)
.030(.76)
.025 (.64)
126-190
.190 (4.8)
.030(.76)
.080 (2.0)
126-090
.090 (2.3)
.030(.76)
.030 (.76)
126-200
.200 (5.1)
.030(.76)
.085 (2.2)
126-100
.100 (2.5)
.030(.76)
.035 (.89)
126-210
.210 (5.3)
.030(.76)
.090 (2.3)
126-110
.110 (2.8)
.030(.76)
.040 (1.0)
126-220
.220 (5.6)
.030(.76)
.095 (2.4)
126-120
.120 (3.0)
.030(.76)
.045 (1.1)
126-230
.230 (5.8)
.030(.76)
.100 (2.5)
126-130
.130 (3.3)
.030(.76)
.050 (1.3)
126-240
.240 (6.1)
.030(.76)
.105 (2.7)
126-030
.030 (.76)
.030(.76)
126-040
.040 (1.0)
.030(.76)
126-050
.050 (1.3)
126-060
000
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
3. NO MEASURABLE AXIAL FLASH ON FEET 8 PL.
2. MATERIAL: NYLON 6/6, 94V-2, WHITE.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
D. Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
DATE:
04/14/03
DATE:
04/14/03
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
PERM-O-PAD TO-5 to TO-18 MOUNT
REVISION:
PART NO:
126-XXX
CAGE CODE : 32559
C
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
