126-090
126-090
    BIVAR
    TO-18
    MOUNT SQUARE TO5/TO18 0.090"
126-090 数据手册
DESCRIPTION REV. B Engineering Update w/o Changes C Removed Material Code 0.100 [2.5mm] SQ. H 0.200 [5.1mm] TYP. APPROVED M. C. J. C. REF. T F DATE 02/16/04 05/22/16 F Ø.330 [Ø8.4mm] Ø.025 [Ø0.6mm] TYP. Ø.070 [Ø1.8mm] TYP. 0.16 [4.0mm] TYP. PART NO. H T F PART NO. H T F 126-140 .140 (3.6) .030(.76) .055 (1.4) .005 (.13) 126-150 .150 (3.8) .030(.76) .060 (1.5) .030(.76) .010 (.25) 126-160 .160 (4.1) .030(.76) .065 (1.7) .060 (1.5) .030(.76) .015 (.38) 126-170 .170 (4.3) .030(.76) .070 (1.8) 126-070 .070 (1.8) .030(.76) .020 (.51) 126-180 .180 (4.6) .030(.76) .075 (1.9) 126-080 .080 (2.0) .030(.76) .025 (.64) 126-190 .190 (4.8) .030(.76) .080 (2.0) 126-090 .090 (2.3) .030(.76) .030 (.76) 126-200 .200 (5.1) .030(.76) .085 (2.2) 126-100 .100 (2.5) .030(.76) .035 (.89) 126-210 .210 (5.3) .030(.76) .090 (2.3) 126-110 .110 (2.8) .030(.76) .040 (1.0) 126-220 .220 (5.6) .030(.76) .095 (2.4) 126-120 .120 (3.0) .030(.76) .045 (1.1) 126-230 .230 (5.8) .030(.76) .100 (2.5) 126-130 .130 (3.3) .030(.76) .050 (1.3) 126-240 .240 (6.1) .030(.76) .105 (2.7) 126-030 .030 (.76) .030(.76) 126-040 .040 (1.0) .030(.76) 126-050 .050 (1.3) 126-060 000 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 3. NO MEASURABLE AXIAL FLASH ON FEET 8 PL. 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: D. Green CHECKED: M. Chen ANGULAR X° ± 1° DATE: 04/14/03 DATE: 04/14/03 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-5 to TO-18 MOUNT REVISION: PART NO: 126-XXX CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
126-090 价格&库存
很抱歉,暂时无法提供与“126-090”相匹配的价格&库存,您可以联系我们找货
      库存:342
