211-040
211-040
    BIVAR
    TO-18
    MOUNT CIRCULAR TO18 0.040"
211-040 数据手册
REV. DESCRIPTION A Engineering Update w/o Changes B Model Update C Removed Material Code DATE APPROVED 02/17/04 11/18/08 05/23/16 M. C. T. Y. J. C. 0.025 [0.6mm] 45° 0.015 [0.4mm] Ø.035 [Ø0.9mm] TYP. 0.043 [1.1mm] 0.150 [3.8mm] TYP. 0.120 [3.0mm] TYP. Ø.190 [Ø4.8mm] 0.268 [6.8mm] 0.020 [0.5mm] Ø.225 [Ø5.7mm] Ø.040 [Ø1.0mm] TYP. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 S. Irving D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-18 MOUNT DATE: 06/30/98 DATE: 02/17/04 PART NO: REVISION: 211-040 CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
211-040 价格&库存
很抱歉,暂时无法提供与“211-040”相匹配的价格&库存,您可以联系我们找货
  • 500+1.90330500+0.24521
  • 1000+1.710341000+0.22035
  • 5000+1.517385000+0.19549
  • 10000+1.3331910000+0.17176
  • 1+5.060861+0.65201
