REV.
DESCRIPTION
C
D
H
0.200 [5.1mm]
TYP.
REF.
F
T
F
Ø.365 [Ø9.3mm]
Ø.050 [Ø1.3mm]
TYP.
Ø.075 [Ø1.9mm]
TYP.
0.20 [5.0mm]
TYP.
Engineering Update w/o Changes
Removed Material Code
DATE
APPROVED
02/23/04
05/22/16
M. C.
J. C.
PART NO.
H
T
F
514-050
.050 (1.3)
.030 (.76)
.010 (.25)
514-060
.060 (1.5)
.030 (.76)
.015 (.38)
514-070
.070 (1.8)
.030 (.76)
.020 (.51)
514-080
.080 (2.0)
.030 (.76)
.025 (.64)
514-090
.090 (2.3)
.030 (.76)
.030 (.76)
514-100
.100 (2.5)
.030 (.76)
.035 (.89)
514-110
.110 (2.8)
.030 (.76)
.040 (1.0)
514-120
.120 (3.0)
.030 (.76)
.045 (1.1)
514-130
.130 (3.3)
.030 (.76)
.050 (1.3)
514-140
.140 (3.6)
.030 (.76)
.055 (1.4)
514-150
.150 (3.8)
.030 (.76)
.060 (1.5)
514-160
.160 (4.1)
.030 (.76)
.065 (1.7)
514-170
.170 (4.3)
.030 (.76)
.070 (1.8)
514-180
.180 (4.6)
.030 (.76)
.075 (1.9)
514-190
.190 (4.8)
.030 (.76)
.080 (2.0)
514-200
.200 (5.1)
.030 (.76)
.085 (2.2)
514-210
.210 (5.3)
.030 (.76)
.090 (2.3)
514-220
.220 (5.6)
.030 (.76)
.095 (2.4)
514-230
.230 (5.8)
.030 (.76)
.100 (2.5)
514-240
.240 (6.1)
.030 (.76)
.105 (2.7)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6/6, 94V-2, WHITE.
± .1
± .01
± .005
DESIGNED:
D. Green
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
PERM-O-PAD TO-5 MOUNT
DATE:
01/16/03
DATE:
01/16/03
PART NO:
REVISION:
514-XXX
CAGE CODE : 32559
D
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“514-090”相匹配的价格&库存,您可以联系我们找货
