388-025
388-025
    BIVAR
    MOUNT RECT CAPACITORS 0.025"
388-025 数据手册
REV. D E DESCRIPTION Engineering Update w/o Changes Removed Material Code DATE APPROVED 02/17/04 05/22/16 M. C. J. C. H F 0.100 [2.5mm] 0.025 [0.6mm] 0.230 [5.8mm] 0.230 [5.8mm] 0.270 [6.9mm] TYP. Ø.030 [Ø0.8mm] 0.060 [1.5mm] TYP. 0.040 [1.0mm] TYP. PART NO. 388-025 388-050 388-075 H .025 (.64) .050 (1.3) .075 (1.9) F .000 .025 (.64) .050 (1.3) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, BLACK. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 S. Irving D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD DISCRETE COMPONENT & CAPACITOR MOUNT DATE: 05/28/98 DATE: 12/02/02 PART NO: REVISION: 388-XXX CAGE CODE : 32559 E SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
388-025 价格&库存
很抱歉,暂时无法提供与“388-025”相匹配的价格&库存,您可以联系我们找货
