506-038
506-038
    BIVAR
    TO-5
    MOUNT CIRCULAR TO5 0.038"
506-038 数据手册
REV. A B C D DATE DESCRIPTION 02/23/04 04/06/06 12/17/13 05/22/16 Engineering Update w/o Changes Changed Dimension Updated Material Notes Removed Material Code 0.200 [5.1mm] APPROVED M. C. M. C. G. W. J. C. 0.038 [1.0mm] TYP. Ø.345 [Ø8.8mm] Ø.039 [Ø1.0mm] TYP. 0.050 [1.3mm] Ø.045 [Ø1.1mm] TYP. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. ± .1 ± .01 ± .005 DESIGNED: S. Irving 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-5 MOUNT DATE: 09/15/98 DATE: 09/23/03 PART NO: REVISION: 506-038 CAGE CODE : 32559 D SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
506-038 价格&库存
很抱歉,暂时无法提供与“506-038”相匹配的价格&库存,您可以联系我们找货
