514-100
514-100
    BIVAR
    TO-5
    MOUNT CIRCULAR TO5 0.100"
514-100 数据手册
REV. DESCRIPTION C D H 0.200 [5.1mm] TYP. REF. F T F Ø.365 [Ø9.3mm] Ø.050 [Ø1.3mm] TYP. Ø.075 [Ø1.9mm] TYP. 0.20 [5.0mm] TYP. Engineering Update w/o Changes Removed Material Code DATE APPROVED 02/23/04 05/22/16 M. C. J. C. PART NO. H T F 514-050 .050 (1.3) .030 (.76) .010 (.25) 514-060 .060 (1.5) .030 (.76) .015 (.38) 514-070 .070 (1.8) .030 (.76) .020 (.51) 514-080 .080 (2.0) .030 (.76) .025 (.64) 514-090 .090 (2.3) .030 (.76) .030 (.76) 514-100 .100 (2.5) .030 (.76) .035 (.89) 514-110 .110 (2.8) .030 (.76) .040 (1.0) 514-120 .120 (3.0) .030 (.76) .045 (1.1) 514-130 .130 (3.3) .030 (.76) .050 (1.3) 514-140 .140 (3.6) .030 (.76) .055 (1.4) 514-150 .150 (3.8) .030 (.76) .060 (1.5) 514-160 .160 (4.1) .030 (.76) .065 (1.7) 514-170 .170 (4.3) .030 (.76) .070 (1.8) 514-180 .180 (4.6) .030 (.76) .075 (1.9) 514-190 .190 (4.8) .030 (.76) .080 (2.0) 514-200 .200 (5.1) .030 (.76) .085 (2.2) 514-210 .210 (5.3) .030 (.76) .090 (2.3) 514-220 .220 (5.6) .030 (.76) .095 (2.4) 514-230 .230 (5.8) .030 (.76) .100 (2.5) 514-240 .240 (6.1) .030 (.76) .105 (2.7) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. ± .1 ± .01 ± .005 DESIGNED: D. Green 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-5 MOUNT DATE: 01/16/03 DATE: 01/16/03 PART NO: REVISION: 514-XXX CAGE CODE : 32559 D SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
514-100 价格&库存
很抱歉,暂时无法提供与“514-100”相匹配的价格&库存,您可以联系我们找货
  • 9+93.219779+12.11415
  • 22+37.4136722+4.86201
  • 100+25.36003100+3.29560
  • 500+22.51591500+2.92600
库存:313
514-100
  • 1+5.000761+0.64986
