337-300
337-300
    BIVAR
    Component Mount Capacitors Rectangular 0.090" (2.29mm) White
337-300 数据手册
REV. C D E F G DESCRIPTION Engineering Update w/o Changes Engineering Table Update Corrected Typos on "F" Dimension Removed Part Numbers from Table Removed Material Code DATE APPROVED 02/17/04 08/27/04 03/06/07 07/17/14 05/22/16 M. C. M. C. M. C. J. C. J. C. 0.046 [1.2mm] 0.125 [3.2mm] 0.145 [3.7mm] 0.030 [0.8mm] Ø.035 [Ø0.9mm] Ø.046 [Ø1.2mm] TYP. TYP. D B C A F HREF. 330 SERIES A 330-200 331-200 .076 (1.9) 332-200 337-300 .176 (4.5) 340-400 341-400 342-400 345-500 346-500 347-500 352-600 355-700 356-700 357-700 B C D 0.094 [2.4mm] F .000 .235 (6.0) .297 (7.5) .030 (.76) .060 (1.5) .335 (8.5) .397 (10.1) .060 (1.5) H .030 (.76) .060 (1.5) .090 (2.3) .090 (2.3) .000 .400 (10.2) .435 (11.0) .497 (12.6) .030 (.76) .060 (1.5) .000 .376 (9.6) .500 (12.7) .535 (13.6) .597 (15.2) .030 (.76) .060 (1.5) .476 (12.1) .600 (15.2) .635 (16.1) .697 (17.7) .060 (1.5) .000 .576 (14.6) .700 (17.8) .735 (18.7) .797 (20.2) .030 (.76) .060 (1.5) .030 (.76) .060 (1.5) .090 (2.3) .030 (.76) .060 (1.5) .090 (2.3) .090 (2.3) .030 (.76) .060 (1.5) .090 (2.3) .200 (5.1) .300 (7.6) .276 (7.0) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. ± .1 ± .01 ± .005 DESIGNED: M. Chen 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 330 SERIES SINGLE & DOUBLE IN-LINE MOUNT TITLE: DATE: 01/30/03 DATE: 01/30/03 REVISION: PART NO: 33X-XXX CAGE CODE : 32559 G SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
337-300 价格&库存
很抱歉,暂时无法提供与“337-300”相匹配的价格&库存,您可以联系我们找货
