500-080
    BIVAR
    TO-5
    MOUNTCIRCULARTO50.071"
500-080 数据手册
REV. DESCRIPTION A Engineering Update w/o Changes B Removed Material Code DATE APPROVED 02/23/04 05/23/16 M. C. J. C. 0.035 [0.9mm] 0.070 [1.8mm] 0.31 [7.8mm] TYP. Ø.370 [Ø9.4mm] Ø.060 [Ø1.5mm] TYP. Ø.225 [Ø5.7mm] STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 S. Irving D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD TO-5 MOUNT DATE: 11/05/98 DATE: 02/23/04 PART NO: REVISION: 500-080 CAGE CODE : 32559 B SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
500-080
物料型号:500-080
器件简介:BIVAR 4THOMAS, IRVINE, CA.92618
引脚分配:未提供
参数特性: - 尺寸:0.035 [0.9mm] 0.070 [1.8mm] 0.31 [7.8mm] Ø.370 [Ø9.4mm] Ø.060 [Ø1.5mm] Ø.225 [Ø5.7mm] - 公差:X ±.1, .XX ±.01, .XXX±.005, ANGULAR: X° ±1° - 材料:NYLON 6/6, 94V-2, WHITE.
功能详解:未提供
应用信息:PERM-O-PAD TO-5 MOUNT
封装信息:未提供
500-080 价格&库存
很抱歉,暂时无法提供与“500-080”相匹配的价格&库存,您可以联系我们找货
    • 500+1.39516
    • 10000+1.33597
    • 1+2.862351+0.35619
    • 10+2.4045910+0.29923
    • 25+2.2553525+0.28066
    • 50+2.1467650+0.26715
    • 100+2.04363100+0.25431
    • 250+1.91502250+0.23831
    • 500+1.82362500+0.22693
    • 1000+1.736421000+0.21608
    • 2500+1.627582500+0.20254
    库存:784
    500-080
      • 500+1.41828500+0.17649
      • 1500+1.391521500+0.17316
      • 2500+1.382602500+0.17205
      • 5000+1.364765000+0.16983
      • 10000+1.3290810000+0.16539
        • 500+1.22204500+0.15207
        • 1000+1.204201000+0.14985
        • 1500+1.195281500+0.14874
        • 2500+1.186362500+0.14763
        • 5000+1.159605000+0.14430
