381-600
    BIVAR
    MOUNT RECT CAPACITORS 0.060"
381-600 数据手册
REV. C D E F G DATE APPROVED 02/17/04 08/27/04 07/17/14 05/07/15 05/23/16 M. C. M. C. J. C. J. C. J. C. DESCRIPTION Engineering Update w/o Changes Engineering Table Update Removed Part Numbers from Table Removed Part Numbers from Table Removed Material Code 0.040 [1.0mm] 0.085 [2.2mm] 0.030 [0.8mm] Ø.035 [Ø0.9mm] Ø.032 [Ø0.8mm] TYP. TYP. D 360 SERIES A 360-200 361-200 .076 (1.9) 362-200 366-300 .176 (4.5) B .200 (5.1) .300 (7.6) C B C A D F .000 .265 (6.7) .297 (7.5) .030 (.76) .060 (1.5) .365 (9.3) .397 (10.1) .030 (7.6) H .030 (.76) .060 (1.5) .090 (2.3) .060 (1.5) 370-400 371-400 372-400 375-500 .376 (9.6) .000 .400 (10.2) .465 (11.8) .497 (12.6) .030 (7.6) .060 (1.5) .500 (12.7) .565 (14.4) .597 (15.2) .000 .030 (.76) .060 (1.5) .090 (2.3) .030 (.76) 381-600 .476 (12.1) .600 (15.2) .665 (16.9) .697 (17.7) .030 (7.6) .060 (1.5) .276 (7.0) 0.053 [1.3mm] F HREF. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 M. Chen D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: 360 SERIES, SINGLE & DOUBLE IN-LINE MOUNT DATE: 01/30/03 DATE: 01/30/03 REVISION: PART NO: 36X-XXX CAGE CODE : 32559 G SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
381-600 价格&库存
很抱歉,暂时无法提供与“381-600”相匹配的价格&库存,您可以联系我们找货
  • 50+1.7394150+0.21756
  • 150+1.70391150+0.21312
  • 500+1.66842500+0.20868
  • 1500+1.632921500+0.20424
  • 5000+1.561925000+0.19536
  • 50+1.4288050+0.17871
  • 150+1.40218150+0.17538
  • 400+1.37556400+0.17205
  • 1000+1.348931000+0.16872
  • 2500+1.295682500+0.16206
  • 1+2.316071+0.28969
  • 10+1.9580310+0.24491
  • 25+1.8333125+0.22931
  • 50+1.7442850+0.21817
  • 100+1.66077100+0.20773
  • 250+1.55610250+0.19464
  • 500+1.48190500+0.18536
  • 1000+1.411011000+0.17649
  • 2500+1.322602500+0.16543
库存:579
