808-187
808-187
    BIVAR
    MOUNT SQUARE IC 8DIP 0.187"
808-187 数据手册
REV. A B .385 [9.8mm] SQ. DESCRIPTION DATE Engineering Release. Defined Material as 21-NL, Colored Blue 06/05/03 07/22/04 APPROVED M. C. M. C. .120 [3.0mm] .100 [2.5mm] TYP. Ø.035 [Ø0.9mm] TYP. .025 [0.6mm] Ø0.06 [Ø1.5mm] TYP. .300 [7.6mm] .315 [8.0mm] Ø.160 [Ø4.1mm] Ø.050 [Ø1.3mm] TYP. .035 [0.9mm] 0.200/0.230 DIA. Lead Entry Tapered STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 3. COLOR PARTS BLUE IN-HOUSE. 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. BIVAR MATERIAL CODE 21-NL. TICONA NYLON 1310, NYLON 6/6, NATURAL. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: David Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD, 8 LEAD DATE: 06/05/03 DATE: 06/05/03 PART NO: REVISION: 808-187 CAGE CODE : 32559 B SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
808-187 价格&库存
很抱歉,暂时无法提供与“808-187”相匹配的价格&库存,您可以联系我们找货
