213-100
213-100
    BIVAR
    TO-18
    MOUNT CIRCULAR TO18 0.100"
213-100 数据手册
molded power transistor mounts Material Specifications: Nylon, per ASTM D 4066 PA111 UL Rated 94V-2 Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) TO-202, TO-220 Part No. L Color 423-125 .125 (3.2) .000 .255 (6.5) Black 423-150 .150 (3.8) .025 (.64) .255 (6.5) Black 423-175 .175 (4.4) .050 (1.3) .255 (6.5) Black 423-200 .200 (5.1) .075 (1.9) .255 (6.5) Black 424-125 .125 (3.2) .000 .280 (7.1) White 424-150 .150 (3.8) .025 (.64) .280 (7.1) White 424-175 .175 (4.4) .050 (1.3) .280 (7.1) White 424-200 .200 (5.1) .075 (1.9) .280 (7.1) White TO-219 Part No. 73 H Price Code: I F TO-247 Price Code: J H F Color Part No. Price Code: J H F Color 422-125 .125 (3.2) .000 Black 426-125 .125 (3.2) .000 Black 422-150 .150 (3.8) .025 (.64) Black 426-150 .150 (3.8) .025 (.64) Black 422-175 .175 (4.4) .050 (1.3) Black 426-175 .175 (4.4) .050 (1.3) Black 422-200 .200 (5.1) .075 (1.9) Black 426-200 .200 (5.1) .075 (1.9) Black www.bivar.com cage code (FSCM) 32559 © copyright 2004 Bivar Inc. extruded power transistor mounts • Standard lengths from .030" - .750" (.76mm - 19.1mm) in .005" (.13mm) increments • Made from semi-rigid PVC UL Rated material Standard Tolerances: O.D. +_ .005 (.13) + _ .005 (.13) I.D. “H” Dim: .030 - .500 (.76 - 12.7) is +_ .005 (.13) “H” Dim: .500 - .750 (12.7 - 19.1) is +_ .008 (.20) Ordering Information: EPM XXX Length Expressed in Thousandths (in .005" increments) (Must be even multiples of .005") 0.030 = 030 0.750 = 750 0.100 = 100 Series: EPM Series EPM Color: Natural Part No. “H” Dimensions Price Code EPM-030 thru EPMH-075 .030-.075 (.76-1.9) W EPM-080 thru EPMH-150 .080-.150 (2.0-3.8) X EPM-155 thru EPMH-230 .155-.230 (4.0-5.8) Y EPM-235 thru EPMH-310 .235-.310 (6.0-7.9) Z EPM-315 thru EPMH-380 .315-.380 (8.0-9.7) ZZ EPM-385 thru EPMH-495 .385-.495 (9.8-12.6) ZZZ EPM-500 thru EPMH-750 .500-.750 (12.7-19.1) ZZZZ cage code (FSCM) 32559 © copyright 2004 Bivar Inc. www.bivar.com 74 capacitor mounts Material Specifications: Natural or black Nylon, per ASTM D 4066 PA111, UL Rated 94V-2 Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = + _ 0.10 (2.5) .X = .XXX = 300 Series A 300-100-022 - 300-100-03 - C .100 (2.5) N.A. .022 (.55) .100 (2.5) .030 (.76) .011 (.28) -008N .100 (2.5) .045 (1.1) .022 (.55) .050 (1.3) .180 (4.6) .090 (2.3) A 300-100-075 - .100 (2.5) .075 (1.9) .022 (.55) .055 (1.4) .180 (4.6) .090 (2.3) A 301-150CS - .150 (3.8) N.A. .022 (.55) .270 (6.9) .125 (3.2) A 301-150-030 - .150 (3.8) .030 (.76) .011 (.28) .090 (2.3) .270 (6.9) .125 (3.2) A 301-150-040 - .150 (3.8) .040 (1.0) .022 (.55) .090 (2.3) .270 (6.9) .125 (3.2) A -009N .150 (3.8) .045 (1.1) .022 (.55) .090 (2.3) .270 (6.9) .125 (3.2) A 301-150 MOD - .150 (3.8) .045 (1.1) .022 (.55) .090 (2.3) .240 (6.1) .090 (2.3) A 302-200-030 - .200 (5.1) .030 (.76) .011 (.28) .090 (2.3) .290 (7.4) .090 (2.3) A 302-200-040 - .200 (5.1) .040 (1.0) .022 (.55) .090 (2.3) .290 (7.4) .090 (2.3) A 302-200 -010N .200 (5.1) .045 (1.1) .022 (.55) .090 (2.3) .290 (7.4) .090 (2.3) A 303-250 -017N .250 (6.4) .045 (1.1) .026 (.66) .090 (2.3) .340 (8.6) .090 (2.3) A 304-300 -018N .300 (7.5) .045 (1.1) .026 (.66) .140 (3.6) .390 (9.9) .090 (2.3) B 305-350 -019N .350 (8.9) .045 (1.1) .030 (.76) .140 (3.6) .440 (11.2) .090 (2.3) B 306-400 -020N .400 (10.2) .045 (1.1) .030 (.76) .190 (4.8) .490 (12.4) .090 (2.3) B 307-500 -021N .500 (12.7) .045 (1.1) .030 (.76) .190 (4.8) .590 (12.4) .090 (2.3) B 301-150 www.bivar.com D E N.A. .180 (4.6) .090 (2.3) A .050 (1.3) .180 (4.6) .090 (2.3) A N.A. F Price Code B 300-100 77 Color: Natural A55485/ M38527/06 Part No. + _ 0.01 (0.25) + _ 0.005 (0.13) cage code (FSCM) 32559 © copyright 2004 Bivar Inc. capacitor mounts Material Specifications: Natural or black Nylon, per ASTM D 4066 PA111, UL Rated 94V-2 Oxygen Rating Index: Over 28% 311 thru 316 Series Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) Color: Natural Part No. A55485/06 M38527/06 A B Price Code 311-200 -023N .300 (7.6) .200 (5.1) A 312-250 -024N .350 (8.9) .250 (6.4) A 313-300 -025N .400 (10.2) .300 (7.6) A 314-350 -026N .450 (11.4) .350 (8.9) B 315-400 -027N .500 (12.7) .400 (10.2) B 316-500 -028N .600 (15.2) .500 (12.7) B 330 Series Discrete Part No. A55485/06 M38527/06 H 330-050 -047N .050 (1.3) .000 A 330-072 -046N .072 (1.8) .022 (.56) A 330-085 -048N .085 (2.2) .035 (.89) A 388 Series Part No. F Price Code Color: Black H F Price Code 388-025 .025 (.64) .000 A 388-050 .050 (1.3) .025 (.64) A 388-075 .075 (1.9) .050 (1.3) A cage code (FSCM) 32559 © copyright 2004 Bivar Inc. www.bivar.com 78 capacitor mounts Single In-Line Mounts • Works with Capacitors, Resistor Networks and any other electrical component with in-line lead configurations Material Specifications: Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) Oxygen Rating Index: Over 28% 3XX Series Part No. A B C D 330-200 331-200 .000 .076 (1.9) .200 (5.1) .235 (6.0) .297 (7.5) 332-200 335-300 336-300 .176 (4.5) .300 (7.6) .335 (8.5) .376 (9.6) .030 (.76) .060 (1.5) .060 (1.5) .090 (2.3) .000 .030 (.76) .500 (12.7) .535 (13.6) .597 (15.2) .030 (.76) .060 (1.5) .060 (1.5) .090 (2.3) .000 .030 (.76) .476 (12.1) .600 (15.2) .635 (16.1) .697 (17.7) 352-600 355-700 357-700 79 www.bivar.com .030 (.76) .000 350-600 356-700 .000 .400 (10.2) .435 (11.0) .497 (12.6) .030 (.76) 347-500 351-600 .090 (2.3) .060 (1.5) 345-500 346-500 .060 (1.5) .060 (1.5) .090 (2.3) 342-400 .576 (14.6) .700 (17.8) .735 (18.7) .797 (20.2) Price Code .030 (.76) .030 (.76) .060 (1.5) 340-400 .276 (7.0) H .397 (10.1) .030 (.76) 337-300 341-400 F .030 (.76) .060 (1.5) .060 (1.5) .090 (2.3) .000 .030 (.76) .030 (.76) .060 (1.5) .060 (1.5) .090 (2.3) A A B B G G cage code (FSCM) 32559 © copyright 2004 Bivar Inc. capacitor mounts Single In-Line Mounts Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) Material Specifications: Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 Oxygen Rating Index: Over 28% 36X, 37X, 38X Series Part No. A B C D 360-200 361-200 .000 .076 (1.9) .200 (5.1) .235 (6.0) .297 (7.5) 362-200 365-300 366-300 .176 (4.5) .300 (7.6) .335 (8.5) .376 (9.6) .030 (.76) .000 .030 (.76) .060 (1.5) .060 (1.5) .090 (2.3) .000 .030 (.76) .500 (12.7) .535 (13.6) .597 (15.2) .030 (.76) .060 (1.5) .060 (1.5) .090 (2.3) .000 .030 (.76) 380-600 .476 (12.1) .600 (15.2) .635 (16.1) .697 (17.7) 382-600 385-700 386-700 .000 .400 (10.2) .435 (11.0) .497 (12.6) .030 (.76) 377-500 381-600 .090 (2.3) .060 (1.5) 375-500 376-500 .060 (1.5) .060 (1.5) .090 (2.3) 372-400 .576 (14.6) .700 (17.8) .735 (18.7) 387-700 cage code (FSCM) 32559 © copyright 2004 Bivar Inc. .797 (20.2) Price Code .030 (.76) .030 (.76) .060 (1.5) 370-400 .276 (7.0) H .397 (10.1) .030 (.76) 367-300 371-400 F .030 (.76) .060 (1.5) .060 (1.5) .090 (2.3) .000 .030 (.76) .030 (.76) .060 (1.5) .060 (1.5) .090 (2.3) A A B B G G www.bivar.com 80 integrated circuit mounts Dual In-Line Mounts Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) Material Specifications: Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 Oxygen Rating Index: Over 28% 814 Series Part No. F H A55485/06 M38527/06 Price Code Color -004N C Natural 814-030 .000 .030 (.76) 814-045 .015 (.38) .045 (1.1) - C Black 814-060 .030 (.76) .060 (1.5) -005N C Natural 814-080 .050 (1.3) .080 (2.0) -006N C Natural 814-100 .070 (1.8) .100 (2.5) - C Black H A55485/06 M38527/06 Price Code 816 Series Part No. F Color 816-030 .000 .030 (.76) - C Black 816-045 .015 (.38) .045 (1.1) - C Black 816-060 .030 (.76) .060 (1.5) -007N C Natural 816-080 .050 (1.3) .080 (2.0) - C Black 816-100 .070 (1.8) .100 (2.5) - C Black H A55485/06 M38527/06 Price Code 818 Series Part No. 81 F Color 818-030 .000 .030 (.76) - C Black 818-045 .015 (.38) .045 (1.1) - C Black 818-060 .030 (.76) .060 (1.5) - C Black 818-080 .050 (1.3) .080 (2.0) - C Black 818-100 .070 (1.8) .100 (2.5) - C Black www.bivar.com cage code (FSCM) 32559 © copyright 2004 Bivar Inc. capacitor mounts ECM: Electrolytic Capacitor Mounts ECI: Electrolytic Capacitor Insulators ECM: Electrolytic Capacitor Mounts Color: Natural • Works with 5mm through 35mm industry standard electrolytic capacitors • Insulates and protects leads • Prevents shorting under shock and vibration Material Specifications: Nylon, per ASTM D4066 PA111, UL Rated 94V-2 Oxygen Rating Index: Over 28% Part No. EC Type I.D. Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) O.D. Thru Hole Foot Dia. Price Code ECM-1 5 .227 (5.8) .287 (7.3) .125 (3.2) .060 (1.5) A ECM-2 6-6.3 .273 (6.9) .333 (8.5) .150 (3.8) .070 (1.8) B ECM-3 8 .345 (8.8) .405 (10.3) .225 (5.7) .070 (1.8) F ECM-4 10 .424 (10.8) .484 (12.3 .250 (6.4) .100 (2.5) F ECM-5 12.5-13 .542 (13.8) .602 (15.3) .350 (8.9) .105 (2.7) G ECM-6 16 .660 (16.8) .720 (18.3) .350 (8.9) .106 (2.7) G ECM-7 18 .738 (18.7) .798 (20.3) .350 (8.9) .106 (2.7) H ECM-8 20 .817 (20.8) .877 (22.3) .441 (11.2) .118 (3.0) H ECM-9 22 .896 (22.8) .956 (24.3) .449 (11.4) .118 (3.0) I ECM-10 25 1.008 (25.6) 1.074 (27.3) .547 (13.9) .138 (3.5) I ECM-11 25.5 1.030 (26.2) 1.090 (27.7) .547 (13.9) .138 (3.5) J ECM-12 30 1.210 (30.5) 1.270 (32.3) .645 (16.4) .138 (3.5) K ECM-13 35 1.410 (35.8) 1.470 (37.3) .645 (16.4) .138 (3.5) C ECI: Electrolytic Capacitor Insulators Color: Clear • Self-retaining • Insulates and allows circuitry beneath capacitor • Transparent, tough and temperature resistant Material Specifications: Dupont, Mylar EL-21 wth UL Rated 94V-2 Oxygen Rating Index: Over 28% Part No. cage code (FSCM) 32559 © copyright 2004 Bivar Inc. Case Style O.D. +-.005 F Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) Use With ECI-1 I .710 (18.0) .394 (10.0) 30 ECI-2 II .830 (21.0) .394 (10.0) 22, 25, 35 www.bivar.com 82 perm-o-pads® TO-18 and T-13/4 (5mm) LED Mounts Material Specifications: White or Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 100-095 Price Code: A Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) 104-020 Price Code: A 108-021 Price Code: A 110-030 Price Code: A 83 www.bivar.com A55485 / 01-040N M38527 / 01-040N 105-021 A55485 / 01-039N M38527 / 01-039N 109-045 A55485 / 01-037N M38527 / 01-037N 111-080 Price Code: A Price Code: A A55485 / 01-031N M38527 / 01-031N Price Code: A cage code (FSCM) 32559 © copyright 2004 Bivar Inc. perm-o-pads® TO-18 and T-13/4 (5mm) LED Mounts Material Specifications: White or Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 112-040 Price Code: A Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = + _ 0.10 (2.5) .X = .XXX = 116-060 Price Code: A 118-055 Price Code: A A55485 / 07-002N M38527 / 07-002N + _ 0.01 (0.25) + _ 0.005 (0.13) A55485 / 01-035N M38527 / 01-035N 117-080 A55485 / 01-036N M38527 / 01-036N 121-032 Price Code: A Price Code: A 123-050 125-080 Price Code: A Price Code: A cage code (FSCM) 32559 © copyright 2004 Bivar Inc. A55485 / 01-034N M38527 / 01-034N www.bivar.com 84 perm-o-pads® TO-18 and T-13/32 (5mm) LED Mounts and TO-18 Spreaders Material Specifications: White or Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) 107-180 Price Code: A 115-100 Price Code: A 120-156 Price Code: A 85 www.bivar.com A55485 / 01-043N M38527 / 01-043N 113-125 A55485 / 01-030N M38527 / 01-030N 119-096 A55485 / 01-044N M38527 / 01-044N 200-115 Price Code: A Price Code: A Price Code: A A55485 / 01-033N M38527 / 01-033N A55485 / 03-013N M38527 / 03-013N cage code (FSCM) 32559 © copyright 2004 Bivar Inc. perm-o-pads® TO-18 and T-13/32 (5mm) LED Mounts and TO-18 Spreaders Material Specifications: White or Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 202-150 Price Code: A Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = + _ 0.10 (2.5) .X = .XXX = 205-085 Price Code: A + _ 0.01 (0.25) + _ 0.005 (0.13) A55485 / 03-002N M38527 / 03-002N 209-125 Price Code: A 211-040 213-100 Price Code: A Price Code: A A55485 / 03-010N M38527 / 03-010N A55485 / 03-004N M38527 / 03-004N 215-130 Price Code: A cage code (FSCM) 32559 © copyright 2004 Bivar Inc. www.bivar.com 86 perm-o-pads® TO-5 Mounts Material Specifications: White or Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 500-080 Price Code: A Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) 501-075 503-075 Price Code: A Price Code: A 506-038 508-075 Price Code: A Price Code: A 509-060 511-038 Price Code: A Price Code: A A55485 / 02-010N M38527 / 02-010N A55485 / 02-047N M38527 / 02-047N A55485 / 02-020N M38527 / 02-020N 87 www.bivar.com cage code (FSCM) 32559 © copyright 2004 Bivar Inc. perm-o-pads® TO-5 Mounts Material Specifications: White or Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 513-075 Price Code: A Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) 515-020 Price Code: A 520-021 Price Code: A A55485 / 02-018N M38527 / 02-018N 516-038 A55485 / 02-019N M38527 / 02-019N 525-038 Price Code: A Price Code: A A55485 / 02-013N M38527 / 02-013N 518-038 A55485 / 02-014N M38527 / 02-014N 526-090 Price Code: A Price Code: A A55485 / 02-038N M38527 / 02-038N 532-050 Price Code: A cage code (FSCM) 32559 © copyright 2004 Bivar Inc. www.bivar.com 88 perm-o-pads® TO-5 and Integrated Circuit Mounts Material Specifications: White or Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 502-120 Price Code: A Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) 505-120 510-110 Price Code: A Price Code: A 512-150 517-095 Price Code: A Price Code: A A55485 / 02-025N M38527 / 02-025N 521-094 Price Code: A 89 www.bivar.com A55485 / 01-041N M38527 / 01-041N 528-117 Price Code: A A55485 / 02-022N M38527 / 02-022N cage code (FSCM) 32559 © copyright 2004 Bivar Inc. perm-o-pads® TO-5 and Integrated Circuit Mounts Material Specifications: White or Natural Nylon, per ASTM D4066 PA111, UL Rated 94V-2 531-218 Price Code: B Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) 535-090 600-080 Price Code: B Price Code: A 6, 8, 10 or 12 Leads 602-038 605-085 Price Code: B Price Code: B 6 Leads Color: Blue, 8 Leads 609-075 616-070 Price Code: B Price Code: B 6 Leads 8 Leads cage code (FSCM) 32559 © copyright 2004 Bivar Inc. A55485 / 02-004N M38527 / 02-004N www.bivar.com 90 perm-o-pads® TO-18 and T-13/32 (5mm) LED Mounts Universal TO-5, to TO-18 and T-13/4 (5mm) LED Mounts Material Specifications: Nylon, per ASTM D4066 PA111, UL Rated 94V-2 Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) TO-18 and T-13/4 (5mm) LED Mounts Part No. 102 Series F Part No. 102-050 .050 (1.3) .030 (.76) H T .010 (.25) 102-130 .130 (3.3) .030 (.76) H T .050 (1.3) F 102-060 .060 (1.5) .030 (.76) .015 (.38) 102-140 .140 (3.6) .030 (.76) .055 (1.4) 102-070 .070 (1.8) .030 (.76) .020 (.51) 102-150 .150 (3.8) .030 (.76) .060 (1.5) 102-080 .080 (2.0) .030 (.76) .025 (.64) 102-160 .160 (4.1) .030 (.76) .065 (1.7) 102-090 .090 (2.3) .030 (.76) .030 (.76) 102-170 .170 (4.3) .030 (.76) .070 (1.8) 102-100 .100 (2.5) .030 (.76) .035 (.89) 102-180 .180 (4.6) .030 (.76) .075 (1.9) 102-110 .110 (2.8) .030 (.76) .040 (1.0) 102-190 .190 (4.8) .030 (.76) .080 (2.0) 102-120 .120 (3.0) .030 (.76) .045 (1.1) 102-200 .200 (5.1) .030 (.76) .085 (2.2) Color: White, Price Code: A 126 Series Universal TO-5 to TO-18 and T-13/4 (5mm) LED Mounts Color: White, Price Code: A Part No. 91 www.bivar.com H T F Part No. H T F 126-030 .030 (.76) .030 (.76) .000 126-140 .140 (3.5) .030 (.76) .055 (1.4) 126-040 .040 (1.0) .030 (.76) .005 (.13) 126-150 .150 (3.8) .030 (.76) .060 (1.5) 126-050 .050 (1.3) .030 (.76) .010 (.25) 126-160 .160 (4.1) .030 (.76) .065 (1.7) 126-060 .060 (1.5) .030 (.76) .015 (.38) 126-170 .170 (4.3) .030 (.76) .070 (1.8) 126-070 .070 (1.8) .030 (.76) .020 (.51) 126-180 .180 (4.6) .030 (.76) .075 (1.9) 126-080 .080 (2.0) .030 (.76) .025 (.64) 126-190 .190 (4.8) .030 (.76) .080 (2.0) 126-090 .090 (2.3) .030 (.76) .030 (.76) 126-200 .200 (5.1) .030 (.76) .085 (2.2) 126-100 .100 (2.5) .030 (.76) .035 (.89) 126-210 .210 (5.3) .030 (.76) .090 (2.3) 126-110 .110 (2.8) .030 (.76) .040 (1.0) 126-220 .220 (5.6) .030 (.76) .095 (2.4) 126-120 .120 (3.0) .030 (.76) .045 (1.1) 126-230 .230 (5.8) .030 (.76) .100 (2.5) 126-130 .130 (3.3) .030 (.76) .050 (1.3) 126-240 .240 (6.1) .030 (.76) .105 (2.7) cage code (FSCM) 32559 © copyright 2004 Bivar Inc. perm-o-pads® TO-5 Mounts Material Specifications: Nylon, per ASTM D4066 PA111, UL Rated 94V-2 Oxygen Rating Index: Over 28% 514 Series Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) Color: White, Price Code: A TO-5 Mounts Part No. H T F Part No. H T F 514-050 .050 (1.3) .030 (.76) .010 (.25) 514-150 .150 (3.8) .030 (.76) .060 (1.5) 514-060 .060 (1.5) .030 (.76) .015 (.38) 514-160 .160 (4.1) .030 (.76) .065 (1.7) 514-070 .070 (1.8) .030 (.76) .020 (.51) 514-170 .170 (4.3) .030 (.76) .070 (1.8) 514-080 .080 (2.0) .030 (.76) .025 (.64) 514-180 .180 (4.6) .030 (.76) .075 (1.9) 514-090 .090 (2.3) .030 (.76) .030 (.76) 514-190 .190 (4.8) .030 (.76) .080 (2.0) 514-100 .100 (2.5) .030 (.76) .035 (.89) 514-200 .200 (5.1) .030 (.76) .085 (2.2) 514-110 .110 (2.8) .030 (.76) .040 (1.0) 514-210 .210 (5.3) .030 (.76) .090 (2.3) 514-120 .120 (3.0) .030 (.76) .045 (1.1) 514-220 .220 (5.6) .030 (.76) .095 (2.4) 514-130 .130 (3.3) .030 (.76) .050 (1.3) 514-230 .230 (5.8) .030 (.76) .100 (2.5) 514-140 .140 (3.6) .030 (.76) .055 (1.4) 514-240 .240 (6.1) .030 (.76) .105 (2.7) cage code (FSCM) 32559 © copyright 2004 Bivar Inc. www.bivar.com 92 vertical mounts Vertical Mounts for Diodes and Resistors • Vertical Mounting Reduces Board Space Requirements Over 50% Material Specifications: Temperature resistant black thermoplastic (PBT) body per MIL-P-46161, Grade B, Class 30, UL Rated 94V-0 Oxygen Rating Index: Over 28% Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = + _ 0.10 (2.5) .X = .XXX = Part No. 93 A Height .312" .437" .562" Single 3121-004 4371-005 5621-006 Double 3122-010 4372-010 5622-012 Triple 3123-016 4373-017 5623-018 Quad 3124-022 4374-023 5624-024 DO-7 1/2 Watt Diodes Resistors DO-34 &35 Use with: Diodes + _ 0.01 (0.25) + _ 0.005 (0.13) D E F 1/8 watt 1/4 watt Resistors Resistors G H B C I J K Price Code 3121-004 .312 (7.9) .100 (2.5) .030 (0.8) .060 (1.5) .050 (1.3) .050 (1.3) .055 (1.4) .030 (0.8) 3122-010 .312 (7.9) .200 (5.1) .030 (0.8) .160 (4.1) .050 (1.3) .050 (1.3) .055 (1.4) .030 (0.8) N/A N/A N/A B .100 (2.5) N/A N/A G 3123-016 .312 (7.9) .300 (7.6) .030 (0.8) .260 (6.6) .050 (1.3) .050 (1.3) .055 (1.4) .030 (0.8) .100 (2.5) .100 (2.5) N/A I 3124-022 .312 (7.9) .400 (10.2) .030 (0.8) .360 (9.1) .050 (1.3) .050 (1.3) .055 (1.4) .030 (0.8) .100 (2.5) .100 (2.5) .100 (2.5) J 4371-005 .437 (11.1) .100 (2.5) .030 (0.8) .060 (1.5) .050 (1.3) .050 (1.3) .055 (1.4) .030 (0.8) N/A N/A N/A F 4372-011 .437 (11.1) .200 (5.1) .030 (0.8) .160 (4.1) .050 (1.3) .050 (1.3) .055 (1.4) .030 (0.8) .100 (2.5) N/A N/A H 4373-017 .437 (11.1) .300 (7.6) .030 (0.8) .260 (6.6) .050 (1.3) .050 (1.3) .055 (1.4) .030 (0.8) .100 (2.5) .100 (2.5) N/A I 4374-023 .437 (11.1) .400 (10.2) .030 (0.8) .360 (9.1) .050 (1.3) .050 (1.3) .055 (1.4) .030 (0.8) .100 (2.5) .100 (2.5) .100 (2.5) J 5621-006 .562 (14.3) .150 (3.8) .040 (1.0) .110 (2.8) .075 (1.9) .075 (1.9) .080 (2.0) .040 (1.0) N/A N/A N/A G 5622-012 .562 (14.3) .300 (7.6) .040 (1.0) .260 (6.6) .075 (1.9) .075 (1.9) .080 (2.0) .040 (1.0) .150 (3.8) N/A N/A I 5623-018 .562 (14.3) .450 (11.4) .040 (1.0) .410 (10.4) .075 (1.9) .075 (1.9) .080 (2.0) .040 (1.0) .150 (3.8) .150 (3.8) N/A J 5624-024 .562 (14.3) .600 (15.2) .040 (1.0) .560 (14.2) .075 (1.9) .075 (1.9) .080 (2.0) .040 (1.0) .150 (3.8) .150 (3.8) .150 (3.8) K www.bivar.com cage code (FSCM) 32559 © copyright 2004 Bivar Inc. crystal mounts Molded Mounts • • • • Elevates Crystal Oscillators from PCB Improves Cooling Efficiency Allows for Proper Inspection of Solder Joints Allows for Traces to be Run Under Component Material Specifications: UL Rated 94V-2 White Nylon per ASTM D4066 PA111 Oxygen Rating Index: Over 28% UL File #E135532 Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.4) .XX = + _ 0.10 (2.5) .X = .XXX = Part No. L IL W IW C/C D + _ 0.01 (0.25) + _ 0.005 (0.13) IH F H Style Price Code 470-015 .495 (12.6) .455 (11.6) .245 (6.2) .205 (5.2) .192 (4.9) .028 (.71) .015 (.38) .000 .050 (1.3) I H 470-025 .495 (12.6) .455 (11.6) .245 (6.2) .205 (5.2) .192 (4.9) .028 (.71) .025 (.64) .010 (.25) .060 (1.5) I H 470-035 .495 (12.6) .455 (11.6) .245 (6.2) .205 (5.2) .192 (4.9) .028 (.71) .035 (.89) .020 (.51) .070 (1.8) I H 470-045 .495 (12.6) .455 (11.6) .245 (6.2) .205 (5.2) .192 (4.9) .028 (.71) .045 (1.1) .030 (.76) .080 (2.0) I H 471-015 .495 (12.6) .455 (11.6) .245 (6.2) .205 (5.2) .192 (4.9) .050 (1.3) .015 (.38) .000 .050 (1.3) II H 471-025 .495 (12.6) .455 (11.6) .245 (6.2) .205 (5.2) .192 (4.9) .050 (1.3) .025 (.64) .010 (.25) .060 (1.5) II H 471-035 .495 (12.6) .455 (11.6) .245 (6.2) .205 (5.2) .192 (4.9) .050 (1.3) .035 (.89) .020 (.51) .070 (1.8) II H 471-045 .495 (12.6) .455 (11.6) .245 (6.2) .205 (5.2) .192 (4.9) .050 (1.3) .045 (1.1) .030 (.76) .080 (2.0) II H cage code (FSCM) 32559 © copyright 2004 Bivar Inc. www.bivar.com 94 crystal insulators Mylar Mounts • Only 0.005" Thick does not increase component height • Insulates component from PCB • Allows for trace to be run under components Material Specifications: UL Rated 94VTM-2 Mylar Film Dupont EL-21 Clear Oxygen Rating Index: Over 28% UL File #E93687 Standard Drawing Tolerances: (unless otherwise indicated) Fractions: +_ 1/64 (0.40) .XX = +_ 0.01 (0.25) + _ 0.10 (2.5) .X = .XXX = +_ 0.005 (0.13) Note: SR Stands for Self Retaining Part No. C C/C L D W Case Style Price Code CI-148-028 - .148 (3.8) .325 (8.3) .028 (.71) .145 (3.7) VI X HC-80/U CI-148-028 SR* - .148 (3.8) .325 (8.3) * .145 (3.7) VI X HC-80/U CI-148-028-3 .074 (1.9) .148 (3.8) .325 (8.3) .028 (.71) .145 (3.7) VI X HC-80/U CI-148-028-3 SR* .074 (1.9) .148 (3.8) .325 (8.3) * .145 (3.7) VI X HC-80/U CI-192-028 - .192 (4.9) .465 (11.8) .028 (.71) .219 (5.6) I X HC-18/U, HC-43/U & HC-49/U CI-192-028 SR* - .192 (4.9) .465 (11.8) * .219 (5.6) I X HC-18/U, HC-43/U & HC-49/U CI-192-028-3 .096 (2.4) .192 (4.9) .465 (11.8) .028 (.71) .219 (5.6) I X HC-18/U, HC-43/U & HC-49/U CI-192-028-3 SR* .096 (2.4) .192 (4.9) .465 (11.8) * .219 (5.6) I X HC-18/U, HC-43/U & HC-49/U .192 (4.9) .465 (11.8) .050 (1.3) .219 (5.6) II X HC-25/U, HC-42/U & HC-50/U .096 (2.4) .192 (4.9) .465 (11.8) .050 (1.3) .219 (5.6) II X HC-25/U, HC-42/U & HC-50/U CI-192-050 CI-192-050-3 95 www.bivar.com Use with - cage code (FSCM) 32559 © copyright 2004 Bivar Inc.
213-100 价格&库存
很抱歉,暂时无法提供与“213-100”相匹配的价格&库存,您可以联系我们找货
