615-075
615-075
    BIVAR
    MOUNT CIRCULAR IC 0.075"
615-075 数据手册
DESCRIPTION REV. DATE A Engineering Update w/o Changes 0.200 [5.1mm] TYP. 02/23/04 APPROVED M. C. 0.055 [1.4mm] 0.075 [1.9mm] Ø.375 [Ø9.5mm] Ø.036 [Ø0.9mm] TYP. Ø.050 [Ø1.3mm] TYP. 22.5° TYP. 45° TYP. 0.30 [7.6mm] TYP. Ø.155 [Ø3.9mm] STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. BIVAR MATERIAL CODE 04-WE. BASF ULTRAMID NYLON 6/6 A3K WHITE. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: Shane Irving CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD IC MOUNT DATE: 11/09/99 DATE: 02/23/04 PART NO: REVISION: 615-075 CAGE CODE : 32559 A SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
615-075 价格&库存
很抱歉,暂时无法提供与“615-075”相匹配的价格&库存,您可以联系我们找货
