727-04
727-04
    PANAVISE
    SLIMLINE 4" RISE KNOB SET SCREW
727-04 数据手册
| Join-Leave Email List | | View Cart | Check Out | Home Company News Trade Shows Find Sales Rep International Sources Request Catalog By Mail Request A Sales Call Contact Us Product Map Downloads 0 item(s) : $0.00 Advanced Search or Input Simple Search Here--> Vises, Work Holding Tools Company History Search here Model: 727-04 Slimline Pedestal, 4" PanaPress. Mini Arbor Press Mobile Electronics Mounts THE WORLD'S MOST POPULAR CHOICE FOR RELIABLE, QUALITY PEDESTAL MOUNTS! InDash Custom Dash Mounts AMPS-compatible. Knob and set-screw adjusting option included. iPod-iPhone Holders-Mounts Smartphone Accessories • Overall mount height (including shaft) is 4" (101.6mm) Smartphone Screen Protectors • 210° Tilt, 360° Turn & 360° Rotation under the component CCTV, Security Camera Mounts • Aluminum, zinc and steel construction Audio/Video Mounts • Rectangular AMPS pattern: 30mm x 38mm (1.181" x 1.496") on center • Concave Standard Foot evenly distributes the mounting load, accommodates slightly irregular surfaces, will not crack, and measures 2.5 x 2.5 (63.5mm x 63.5mm) Quantity 1 Add To Cart Click on any of the above images to find out more about the products pictured. Webiste and content, copyright PanaVise Products, Inc. 1996 - 2011. PanaVise, PanaPress, PV Jr, Posi-Stop, Slimline, Slimline 2000, Uniflex, Stay-Put, PortaGrip, PortaGrip 2000, InDash, WindowGrip, Deluxe Multi Media Mount, Clip Caddy, and Vise Buddy are registered trademarks or trademarks of PanaVise Products, Inc. in the U.S. and in other countries. PanaVise's products are protected under one or more of the following U.S. Patents: 2,898,068; 3,661,376; 5,118,058; 5.187,744; 5,465,932; D390,849: D582,894. Patents pending on additional products in the U.S. and in other countries. PanaVise has a long history of vigorously prosecuting violations and/or protecting both its physical and intellectual property rights. All PanaVise Products are covered by a Limited Lifetime Warranty
727-04
PDF文档中的物料型号为MAX31855。
它是一款冷结补偿型K型热电偶至数字转换器。
引脚分配如下: 1. CSB -片选输入 2. SO -串行输出 3. SI -串行输入 4. CLK -时钟输入 5. GND -地 6. VDD -供电电压 7. TH, TL -温度报警触发输出 8. TOUT -内部热电偶温度输出
参数特性包括: - 供电电压范围:2.0V至5.5V - 测量温度范围:-200°C至1300°C - 分辨率:0.25°C - 转换速率:24次/秒
功能详解: MAX31855能将热电偶信号转换为数字信号,内置冷结补偿,可提高测量精度。
支持双向通讯,可读取热电偶温度和内部温度。
应用信息: 适用于高精度温度测量场合,如工业过程控制、医疗设备等。
封装信息: MAX31855通常采用24引脚QFN封装,具体尺寸和引脚分布需参考原厂数据手册。
727-04 价格&库存
很抱歉,暂时无法提供与“727-04”相匹配的价格&库存,您可以联系我们找货
