1000 Eaton Boulevard
Cleveland, OH 44122
United States
Full Motion Ceiling Mount for 23" to 42" TVs and
Monitors.
MODEL NUMBER: DCTM
Highlights
Fits most flat-panel displays
from 23 to 42 in.
One-touch adjustment for
comfortable viewing
90° swivel and -20° tilt for wide
range of motion
Supports up to 66 lbs (30 kgs)
Package Includes
Suspends a flat-panel television, monitor or other display from the ceiling, which saves valuable wall and
floor space. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants.
Description
The DCTM Full Motion Ceiling Mount saves valuable wall and floor space by suspending your flat-panel
television, monitor or other display from the ceiling. Ideal for home theaters, classrooms, boardrooms,
hotels, bars and restaurants, it fits most flat-panel displays from 23 to 42 inches.
The DCTM adjusts with one easy touch to customize your viewing at any time. A 90° swivel and -20° tilt
capability minimizes glare and provides comfortable viewing from multiple angles.
The durable all-metal pole extends from 24 to 34 inches and supports up to 66 lbs (30 kgs). The scratchresistant powder-coated finish tolerates frequent handling and blends with any décor. Installation
hardware is included. Conforms to VESA-compliant displays with any of the following mounting hole
patterns: 75 x 75 mm, 75 x 100 mm, 75 x 200 mm, 100 x 75 mm, 100 x 100 mm, 100 x 200 mm, 200 x
75mm, 200 x 100 mm and 200 x 200 mm.
Features
Save Valuable Wall and Floor SpaceSuspends flat-panel TV, monitor or other display from ceilingFits
most flat-panel devices from 23 to 42 in.Installation hardware includedIdeal for home theaters,
Convenient One-Touch Adjustment90° swivel and -20° tilt capability provides comfortable viewing from
multiple angles
Durable Metal ConstructionSupports up to 66 lbs (30 kgs)Pole extends from 24 to 34 in.Scratchresistant powder-coated finish blends with any décor
VESA ComplianceSupports the following VESA mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 75 x
200 mm, 100 x 75 mm, 100 x 100 mm, 100 x 200 mm, 200 x 75mm, 200 x 100 mm and 200 x 200 mm
Specifications
OVERVIEW
1/3
DCTM
Hardware packet
Owner's Manual
Cleveland, OH 44122
United States
UPC Code
037332223456
Device Compatibility
Monitor/HDTV
PHYSICAL
Color
Black
Material of Construction
Steel
VESA Pattern (mm)
100x100; 100x200; 100x75; 200x100; 200x200; 200x75; 75x100; 75x200; 75x75
Motion
Full
Mounting Location
Ceiling
Degrees of Motion
-20 Tilt; 90 Swivel
Minimum Screen Size (in.)
23
Minimum Screen Size (cm)
58.42
Maximum Screen Size (in.)
42
Maximum Screen Size (cm)
106.68
Maximum Weight Capacity (lbs.)
66
Maximum Weight Capacity (kg)
30
Min/Max Arm Extension (in.)
24 min to 34 max
Number of Displays
1
Shipping Dimensions (hwd / in.)
21.10 x 9.80 x 20.10
Shipping Dimensions (hwd / cm)
53.59 x 24.89 x 51.05
Shipping Weight (lbs.)
5.30
Shipping Weight (kg)
2.40
Unit Dimensions (hwd / in.)
5.400 x 6.300 x 38.000
Unit Dimensions (hwd / cm)
13.72 x 16 x 96.52
Unit Weight (lbs.)
4.9
Unit Weight (kg)
2.22
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Antimicrobial
No
Cord Management
No
Tools Necessary
Yes
Security Lock
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; RoHS3; CE (Europe); REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“DCTM”相匹配的价格&库存,您可以联系我们找货
