DWM2655M
DWM2655M
    TRIPPLITE
    TVWALLMOUNT
DWM2655M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Swivel/Tilt Wall Mount for 26" to 55" TVs and Monitors MODEL NUMBER: DWM2655M Highlights ● Fits most flat-panel displays from 26 to 55 in. ● One-touch adjustment for comfortable viewing ● 120° swivel, -15° to +15° tilt and -5° to +5° screen adjustment ● Supports up to 110 lbs (49.9 kgs) Package Includes Hangs a flat-panel television, monitor or other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants. Swivels and tilts to provide optimal viewing angles. Description The VESA-compliant DWM2655M Swivel/Tilt Wall Mount allows you to mount your flat-panel television, monitor or other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants, it fits most flat-panel displays from 26 to 55 inches. Adjust the display’s viewing angle to fit your environment and comfort level. A 120° swivel, -15° to +15° tilt and -5° to +5° screen level adjustment capability minimizes glare and provides comfortable viewing from multiple angles. Durable all-metal frame with scratch-resistant powder-coated finish supports up to 110 lbs (49.9 kgs). Mounting hardware included. Built-in bubble level allows accurate display leveling. Conforms to VESAcompliant displays with any of the following mounting hole patterns: 100 x 100 mm, 100 x 200 mm, 200 x 100 mm, 200 x 200 mm, 200 x 300 mm, 200 x 400 mm, 300 x 200 mm, 300 x 300 mm, 300 x 400 mm, 400 x 200 mm, 400 x 300 mm and 400 x 400 mm Features Mounts Your TV or Monitor to the WallFits most flat-panel televisions, monitors and other displays from 26 to 55 in.Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurantsViewing angle adjusts to fit your environment and comfort levelMounting hardware included Convenient One-Touch Adjustment120° swivel, -15° to +15° tilt and -5° to +5° screen level adjustment capability provides comfortable viewing from multiple angles Durable Metal ConstructionSupports up to 110 lbs (49.9 kgs)Scratch-resistant powder-coated finish blends with any décorBuilt-in bubble level allows accurate display leveling VESA ComplianceSupports the following VESA mounting hole patterns: 100 x 100 mm, 100 x 200 mm, 200 x 100 mm, 200 x 200 mm, 200 x 300 mm, 200 x 400 mm, 300 x 200 mm, 300 x 300 mm, 300 x 400 mm, 400 x 200 mm, 400 x 300 mm and 400 x 400 mm Specifications 1/3 ● DWM2655M Swivel/Tilt Wall Mount for 26" to 55" TVs and Monitors ● (4) M5 x 14 screws ● (4) M6 x 14 screws ● (4) M6 x 30 screws ● (4) M8 x 20 screws ● (4) M8 x 30 screws ● (4) Washers ● (8) Small spacers ● (4) Big spacers ● (6) Anchor bolts ● (6) Concrete anchors ● (6) D6 washers ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332183637 Device Compatibility Monitor/HDTV PHYSICAL Color Black Material of Construction Steel VESA Pattern (mm) 100x100; 100x200; 200x100; 200x200; 200x300; 200x400; 300x200; 300x300; 300x400; 400x200; 400x300; 400x400 Motion Full Mounting Location Wall Degrees of Motion -15/+15 Tilt; 120 Swivel; -5/+5 Level Adjustment Minimum Screen Size (in.) 26 Minimum Screen Size (cm) 66.04 Maximum Screen Size (in.) 55 Maximum Screen Size (cm) 139.7 Maximum Weight Capacity (lbs.) 110 Maximum Weight Capacity (kg) 50 Min/Max Arm Extension (in.) 4.92 min to 20.27 max Min/Max Arm Extension (cm) 12.5 min to 51.5 max Number of Displays 1 Shipping Dimensions (hwd / in.) 4.60 x 21.90 x 9.20 Shipping Dimensions (hwd / cm) 11.68 x 55.63 x 23.37 Shipping Weight (lbs.) 19.06 Shipping Weight (kg) 8.65 Unit Dimensions (hwd / in.) 7.670 x 16.850 x 16.850 Unit Dimensions (hwd / cm) 20.32 x 51.5 x 19.5 Unit Weight (lbs.) 18.45 Unit Weight (kg) 8.37 Assembly Required Yes FEATURES & SPECIFICATIONS Antimicrobial No Cord Management No Tools Necessary Yes Security Lock No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Compliance RoHS; RoHS3; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
DWM2655M
物料型号:DWM2655M 器件简介:这是一款符合VESA标准的可旋转/倾斜式壁挂架,适用于26至55英寸的平板电视、显示器或其他显示屏。
引脚分配:支持多种VESA安装孔模式,包括100x100mm、100x200mm、200x100mm、200x200mm、200x300mm、200x400mm、300x200mm、300x300mm、300x400mm、400x200mm、400x300mm和400x400mm。
参数特性:支持最大110磅(49.9公斤)的重量,具有120°旋转、-15°至+15°倾斜和-5°至+5°屏幕水平调整功能,以最小化眩光并提供舒适的多角度观看体验。
功能详解:壁挂架可以旋转和倾斜,以提供最佳的观看角度。
耐用的全金属框架采用抗刮擦的粉末涂层,支持高达110磅的重量。
内置的气泡水平仪可以准确调整显示屏的水平。
应用信息:适用于家庭影院、教室、会议室、酒店、酒吧和餐馆。
封装信息:产品包括DWM2655M可旋转/倾斜式壁挂架、螺丝、垫圈、间隔器和安装锚固螺栓等安装硬件,以及用户手册。
DWM2655M 价格&库存
很抱歉,暂时无法提供与“DWM2655M”相匹配的价格&库存,您可以联系我们找货
