DDR1032SE
DDR1032SE
    TRIPPLITE
    TV DESK MNT
DDR1032SE 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Single Monitor Mount Stand for 10" to 32" FlatScreen Displays MODEL NUMBER: DDR1032SE Highlights ● Fits most flat-panel displays from 10 to 32 in. ● One-touch adjustment for comfortable viewing ● 180° swivel and -15° to +15° tilt for wide range of motion ● Supports up to 36 lbs (16.3 kgs) Package Includes Mounts your monitor on a base to free up valuable space on your desk, table or workstation. Ideal for home or office use. Description The VESA-compliant DDR1032SE Single Monitor Mount Stand mounts your monitor on a sturdy base, allowing you to free up valuable workspace on your desk, table or workstation. Ideal for home and office, the DDR1032SE fits most flat-panel displays from 10 to 32 inches. Position your monitor with one-touch ease to optimize viewing angle and height to fit your environment and comfort level. A 180° swivel and -15° to +15° tilt capability minimizes glare and provides comfortable viewing from multiple angles. A 360° rotation lets you view your monitor in portrait or landscape orientation. Mount supports up to 36 lbs (16.3 kgs). The durable all-metal frame with scratch-resistant powder-coated finish tolerates frequent handling and blends with any décor. Mounting hardware is included. Conforms to VESA-compliant displays with any of the following mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 100 x 75 mm, and 100 x 100 mm. Features Mounts Your Monitor on a BaseFrees up valuable workspace on your desk, table or workstationFits most flat-panel displays from 10 to 32 in.Mount adjusts independently for viewing angle and heightIdeal for home and office use Convenient One-Touch Adjustment180° swivel and -15° to +15° tilt capability provides comfortable viewingFull 360° rotation for viewing in portrait or landscape orientation Durable Metal ConstructionMount supports up to 36 lbs (16.3 kgs)Scratch-resistant powder-coated finish blends with any décorMounting hardware included VESA ComplianceSupports the following VESA mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 100 x 75 mm, and 100 x 100 mm Specifications OVERVIEW 1/3 ● Pole ● Base ● Mounting assembly ● Top cap ● (4) M6 screws ● (4) M4 screws ● (4) M6 lock washers ● (4) Washers ● (4) Spacers ● (2) Hex keys ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332181763 Device Compatibility Monitor/HDTV PHYSICAL Color Black Material of Construction Steel VESA Pattern (mm) 100x100; 100x75; 75x100; 75x75 Motion Full Mounting Location Desktop Degrees of Motion -15/+15 Tilt; 180 Swivel; 360 Rotate Minimum Screen Size (in.) 10 Minimum Screen Size (cm) 25.4 Maximum Screen Size (in.) 32 Maximum Screen Size (cm) 81.28 Maximum Weight Capacity (lbs.) 36 Maximum Weight Capacity (kg) 16 Number of Displays 1 Shipping Dimensions (hwd / in.) 6.60 x 11.60 x 18.40 Shipping Dimensions (hwd / cm) 16.76 x 29.46 x 46.74 Shipping Weight (lbs.) 9.30 Shipping Weight (kg) 4.22 Unit Dimensions (hwd / in.) 15.160 x 16.770 x 10.100 Unit Dimensions (hwd / cm) 39.88 x 25.91 x 37.8 Unit Weight (lbs.) 5.50 Unit Weight (kg) 2.49 Assembly Required Yes FEATURES & SPECIFICATIONS Antimicrobial No Cord Management No Tools Necessary Yes Security Lock No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
DDR1032SE 价格&库存
很抱歉,暂时无法提供与“DDR1032SE”相匹配的价格&库存,您可以联系我们找货
