DDR1327SQFC
DDR1327SQFC
    TRIPPLITE
    TVDESKMNT
DDR1327SQFC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Quad Full Motion Flex Arm Desk Clamp for 13" to 27" Monitors MODEL NUMBER: DDR1327SQFC Highlights ● Fits most flat-panel displays from 13 to 27 in. ● One-touch adjustment for comfortable viewing ● 180° swivel and -15° to +15° tilt for wide range of motion ● Each swivel arm supports up to 22 lbs (9.9 kgs) Package Includes Mounts up to 4 monitors off the surface of your desk, table or workstation to free up valuable space. Ideal for home or office use. Description The VESA-compliant DDR1327SQFC Quad Full Motion Flex Arm Desk Clamp attaches to your desk, table or workstation, allowing you to mount up to four monitors above it and free up valuable workspace. Ideal for home and office, the DDR1327SQFC fits most flat-panel displays from 13 to 27 inches. Swivel arms can be independently adjusted for angle to give you maximum flexibility in positioning your monitors to fit your environment and comfort level. Move a screen closer to you, and push screens out of your way when not in use. A 180° swivel and -15° to +15° tilt capability minimizes glare and provides comfortable viewing from multiple angles. A 360° rotation lets you view your monitor in portrait or landscape orientation. Durable clamp attaches to most flat surfaces up to 3.5 inches thick with a firm grip, or you can install it using a desk hole up to 2.75 inches in diameter. Each swivel arm supports up to 22 lbs (9.9 kgs). The durable all-metal frame with scratch-resistant powder-coated finish tolerates frequent handling and blends with any décor. Mounting hardware is included. Conforms to VESA-compliant displays with any of the following mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 100 x 75 mm, and 100 x 100 mm Features Attaches to Most Desks, Tables and WorkstationsClamps securely to most flat surfaces from 0.4 in. to 3.5 in. to mount up to 4 monitorsAlso attaches to desk using surface hole from 0.4 in. to 2.75 in. diameterFits most flat-panel displays from 13 to 27 in.Swivel arms adjust independently for angleIdeal for home and office use Convenient One-Touch Adjustment180° swivel and -15° to +15° tilt capability provides comfortable viewing from multiple anglesFull 360° rotation for viewing in portrait or landscape orientation Durable Metal ConstructionEach swivel arm supports up to 22 lbs (9.9 kgs)Scratch-resistant powdercoated finish blends with any décorMounting hardware includedDisplay cables attach to mount to reduce clutter VESA ComplianceSupports the following VESA mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 100 x 75 mm, and 100 x 100 mm Specifications 1/3 ● (2) Adapter bracket assemblies ● Top pole ● Bottom pole ● Connector ● Desk clamp assembly ● (16) M4 screws ● (16) M5 screws ● (16) D5 washers ● Base plate ● Pad ● Hex key, 3 mm ● Hex key, 4 mm ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332184870 Device Compatibility Monitor/HDTV PHYSICAL Color Black Material of Construction Steel VESA Pattern (mm) 100x100; 100x75; 75x100; 75x75 Motion Full Mounting Location Desk Clamp Degrees of Motion -15/+15 Tilt; 180 Swivel; 360 Rotate Minimum Screen Size (in.) 13 Minimum Screen Size (cm) 33.02 Maximum Screen Size (in.) 27 Maximum Screen Size (cm) 68.58 Maximum Weight Capacity (lbs.) 22 Maximum Weight Capacity (kg) 10 Number of Displays 4 Shipping Dimensions (hwd / in.) 6.80 x 22.60 x 11.10 Shipping Dimensions (hwd / cm) 17.27 x 57.40 x 28.19 Shipping Weight (lbs.) 17.00 Shipping Weight (kg) 7.71 Unit Dimensions (hwd / in.) 34.650 x 33.620 x 4.530 Unit Dimensions (hwd / cm) 88,01 x 85,39 x 11,50 Unit Weight (lbs.) 13.4 Unit Weight (kg) 6.08 FEATURES & SPECIFICATIONS Cord Management Yes Tools Necessary Yes Security Lock No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
DDR1327SQFC 价格&库存
很抱歉,暂时无法提供与“DDR1327SQFC”相匹配的价格&库存,您可以联系我们找货
