1000 Eaton Boulevard
Cleveland, OH 44122
United States
Dual Full Motion Flex Arm Desk Clamp for 13" to
27" Monitors / Displays
MODEL NUMBER: DDR1327DCS
Highlights
Fits most flat-panel displays
from 13 to 27 in.
One-touch adjustment for
comfortable viewing
180° swivel and -80° to +90° tilt
for wide range of motion
Each swivel arm supports up to
22 lbs (9.9 kgs)
Package Includes
Mounts 2 monitors off the surface of your desk, table or workstation to free up valuable space. Tilts from 80° to +90°. Ideal for home or office use.
Description
The VESA-compliant DDR1327DCS Dual Full Motion Flex Arm Desk Clamp attaches to your desk, table
or workstation, allowing you to mount two monitors above it and free up valuable workspace. Ideal for
home and office, the DDR1327DCS fits most flat-panel displays from 13 to 27 inches.
Dual swivel arms can be independently adjusted for angle and height to give you maximum flexibility in
positioning your monitors to fit your environment and comfort level - Note: Arms cannot be positioned
directly across from each other.. Move a screen closer to you, or push both screens out of your way when
not in use. A 180° swivel and -80° to +90° tilt capability minimizes glare and provides comfortable viewing
from multiple angles. A 360° rotation lets you view your monitors in portrait or landscape orientation.
Durable clamp attaches to most flat surfaces up to 2.4 inches thick for a firm grip. Each swivel arm
supports up to 22 lbs (9.9 kgs). The durable all-metal frame with scratch-resistant powder-coated finish
tolerates frequent handling and blends with any décor. Conforms to VESA-compliant displays with any of
the following mounting hole patterns: 75 x 75 mm and 100 x 100 mm.
Features
Attaches to Most Desks, Tables and Workstations
● Clamps securely to most flat surfaces from 0.4 in. to 2.4 in.
Fits most flat-panel displays from 13 to 27 in.
Dual swivel arms adjust independently for angle and height - Note: Arms adjust independently and
cannot be positioned directly across from each other
Ideal for home and office use
Convenient One-Touch Adjustment
● 180° swivel and -80° to +90° tilt capability provides comfortable viewing from multiple angles
Full 360° rotation for viewing in portrait or landscape orientation
Durable Metal Construction
● Each swivel arm supports up to 22 lbs (9.9 kgs)
Scratch-resistant powder-coated finish blends with any décor
1/3
Desk mount assembly
End cap
(2) Arms
(2) Mounting assemblies
(3) Collars
(2) Sleeves
(2) Knobs
(8) M4 screws
(8) M5 screws
(8) Washers
Hex key, 4 mm
Hex key, 6 mm
Owner’s manual
Cleveland, OH 44122
United States
Mounting hardware included
VESA Compliance
● Supports the following VESA mounting hole patterns: 75 x 75 mm and 100 x 100 mm
Specifications
OVERVIEW
UPC Code
037332187116
Device Compatibility
Monitor/HDTV
PHYSICAL
Color
Black; Silver
Material of Construction
Steel
VESA Pattern (mm)
75x75; 100x100
Motion
Full
Mounting Location
Desk Clamp
Degrees of Motion
-80/+90 Tilt; 180 Swivel; 360 Rotate
Minimum Screen Size (in.)
13
Minimum Screen Size (cm)
33.02
Maximum Screen Size (in.)
27
Maximum Screen Size (cm)
68.58
Maximum Weight Capacity (lbs.)
22
Maximum Weight Capacity (kg)
10
Number of Displays
2
Shipping Dimensions (hwd / in.)
4.90 x 9.70 x 20.40
Shipping Dimensions (hwd / cm)
12.45 x 24.64 x 51.82
Shipping Weight (lbs.)
8.80
Shipping Weight (kg)
3.99
Unit Dimensions (hwd / in.)
12.520 x 33.860 x 4.450
Unit Dimensions (hwd / cm)
31.80 x 86.0 x 11.30
Unit Weight (lbs.)
6.56
Unit Weight (kg)
2.98
Assembly Required
Yes
2/3
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Antimicrobial
No
Cord Management
Yes
Tools Necessary
Yes
Security Lock
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; RoHS3; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“DDR1327DCS”相匹配的价格&库存,您可以联系我们找货
