1000 Eaton Boulevard
Cleveland, OH 44122
United States
Tilt Wall Mount for 45" to 85" TVs and Monitors
Highlights
Fits most flat-panel displays
from 45 to 85 in.
Hangs out of sight for a sleek,
professional appearance
-10° to +10° tilt capability for
comfortable viewing
Supports up to 200 lbs (90.7
kgs)
MODEL NUMBER: DWT4585X
Package Includes
Low-profile mount hangs a flat-panel television, monitor or other display on the wall. Ideal for home
theaters, classrooms, boardrooms, hotels, bars and restaurants. Tilts to provide optimal viewing angles.
Description
The VESA-compliant DWT4585X Tilt Wall Mount allows you to mount your flat-panel television, monitor or
other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants,
it fits most flat-panel displays from 45 to 85 inches. A -10° to +10° tilt capability minimizes glare and
provides comfortable viewing from multiple angles.
Low-profile mount is concealed behind the display to give a sleek, professional appearance. Frame is
open for easy wall access. Mounting rails adjust horizontally to compensate for off-center wall studs. Builtin bubble level allows accurate display leveling. Durable all-metal frame with scratch-resistant powdercoated finish supports up to 200 lbs (90.7 kgs). Mounting hardware included. Conforms to VESAcompliant displays with any of the following mounting hole patterns: 200 x 200 mm, 200 x 300 mm, 200 x
400 mm, 300 x 200 mm, 300 x 300 mm, 300 x 400 mm, 400 x 200 mm, 400 x 300 mm, 400 x 400 mm,
500 x 300 mm, 500 x 400 mm, 600 x 300 mm, 600 x 400 mm, 800 x 300 mm and 800 x 400 mm
Features
Mounts Your TV or Monitor to the WallFits most flat-panel televisions, monitors and other displays from
45 to 85 in.Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurantsMounts out of
sight behind display for sleek, professional appearanceMounting hardware included
Convenient One-Touch Adjustment-10° to +10° tilt capability provides comfortable viewing from
multiple anglesImproves viewing angles in applications where audience is below the display
Durable Metal ConstructionSupports up to 200 lbs (90.7 kgs).Open frame allows easy wall
accessAdjustable mounting rails compensate for off-center wall studsBuilt-in bubble level for accurate
display levelingScratch-resistant powder-coated finish
VESA ComplianceSupports the following VESA mounting hole patterns: 200 x 200 mm, 200 x 300 mm,
200 x 400 mm, 300 x 200 mm, 300 x 300 mm, 300 x 400 mm, 400 x 200 mm, 400 x 300 mm, 400 x 400
mm, 500 x 300 mm, 500 x 400 mm, 600 x 300 mm, 600 x 400 mm, 800 x 300 mm and 800 x 400 mm
Specifications
OVERVIEW
1/3
DWT4585X Tilt Wall Mount for
(4) M5 x 14 screws
(4) M6 x 14 screws
(4) M6 x 30 screws
(4) M8 x 20 screws
(4) M8 x 30 screws
(4) Washers
(8) Small spacers
(4) Big spacers
(6) Anchor bolts
(6) Concrete anchors
(6) D6 washers
Owner’s manual
Cleveland, OH 44122
United States
UPC Code
037332186461
Device Compatibility
Monitor/HDTV
PHYSICAL
Color
Black
Material of Construction
Steel
VESA Pattern (mm)
200x200; 200x300; 200x400; 300x200; 300x300; 300x400; 400x200; 400x300; 400x400; 500x300; 500x400;
600x300; 600x400; 800x300; 800x400
Motion
Tilt
Mounting Location
Wall
Degrees of Motion
-10/+10 Tilt
Distance from Wall (in.)
2.48
Distance from Wall (cm)
6
Distance from Wall (mm)
63
Minimum Screen Size (in.)
45
Minimum Screen Size (cm)
114.3
Maximum Screen Size (in.)
85
Maximum Screen Size (cm)
215.9
Maximum Weight Capacity (lbs.)
200
Maximum Weight Capacity (kg)
91
Number of Displays
1
Shipping Dimensions (hwd / in.)
2.70 x 6.20 x 35.20
Shipping Dimensions (hwd / cm)
6.86 x 15.75 x 89.41
Shipping Weight (lbs.)
9.10
Shipping Weight (kg)
4.13
Unit Dimensions (hwd / in.)
17.320 x 33.850 x 2.480
Unit Dimensions (hwd / cm)
43.99 x 85.98 x 6.30
Unit Weight (lbs.)
6.75
Unit Weight (kg)
3.06
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Antimicrobial
No
Cord Management
No
Tools Necessary
Yes
Security Lock
No
2/3
Cleveland, OH 44122
United States
STANDARDS & COMPLIANCE
Product Compliance
RoHS; RoHS3; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
