DDR1026SD
DDR1026SD
    TRIPPLITE
    TVDESKMNT
DDR1026SD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Dual Monitor Mount Stand for 10" to 26" FlatScreen Displays MODEL NUMBER: DDR1026SD Highlights ● Fits most flat-panel displays from 10 to 26 in. ● One-touch adjustment for comfortable viewing ● 180° swivel and -15° to +15° tilt for wide range of motion ● Each mount supports up to 30 lbs (13.6 kgs) Package Includes Mounts two 10–26 in. monitors on a single base to free up valuable space on your desk, table or workstation. Ideal for home or office use. Description The VESA-compliant DDR1026SD Dual Monitor Mount Stand mounts two monitors on a sturdy base, allowing you to free up valuable workspace on your desk, table or workstation. Ideal for home and office, the DDR1026SD fits most flat-panel displays from 10 to 26 inches. Position your monitors with one-touch ease to optimize viewing angle and height to fit your environment and comfort level. A 180° swivel and -15° to +15° tilt capability minimizes glare and provides comfortable viewing from multiple angles. A 360° rotation lets you view your monitors in portrait or landscape orientation. Each mount supports up to 30 lbs (13.6 kgs). The durable all-metal frame with scratch-resistant powdercoated finish tolerates frequent handling and blends with any décor. Mounting hardware is included. Conforms to VESA-compliant displays with any of the following mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 100 x 75 mm, and 100 x 100 mm. Features Mounts 2 Monitors on a BaseFrees up valuable workspace on your desk, table or workstationFits most flat-panel displays from 10 to 26 in.Mounts adjust independently for viewing angleIdeal for home and office use Convenient One-Touch Adjustment180° swivel and -15° to +15° tilt capability provides comfortable viewingFull 360° rotation for viewing in portrait or landscape orientation Durable Metal ConstructionEach mount supports up to 30 lbs (13.6 kgs)Scratch-resistant powdercoated finish blends with any décorMounting hardware included VESA ComplianceSupports the following VESA mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 100 x 75 mm, and 100 x 100 mm Specifications 1/3 ● Pole ● Base ● Mounting assembly ● Top cap ● (8) M6 screws ● (8) M4 screws ● (8) Lock washers ● (8) Washers ● (8) Spacers ● Handle and washer ● Hex key, 2.5 mm ● Hex key, 4 mm ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332181909 Device Compatibility Monitor/HDTV PHYSICAL Color Black Material of Construction Steel VESA Pattern (mm) 100x100; 100x75; 75x100; 75x75 Motion Full Mounting Location Desktop Degrees of Motion -15/+15 Tilt; 180 Swivel; 360 Rotate Minimum Screen Size (in.) 10 Minimum Screen Size (cm) 25.4 Maximum Screen Size (in.) 26 Maximum Screen Size (cm) 66.04 Maximum Weight Capacity (lbs.) 30 Maximum Weight Capacity (kg) 14 Number of Displays 2 Shipping Dimensions (hwd / in.) 5.71 x 12.00 x 31.50 Shipping Dimensions (hwd / cm) 14.50 x 30.48 x 80.01 Shipping Weight (lbs.) 14.61 Shipping Weight (kg) 6.63 Unit Dimensions (hwd / in.) 15.160 x 28.900 x 10.860 Unit Dimensions (hwd / cm) 39,88 x 73,41 x 25,91 Unit Weight (lbs.) 8.50 Unit Weight (kg) 3.86 FEATURES & SPECIFICATIONS Cord Management No Tools Necessary Yes Security Lock No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty Product Warranty Period (U.S. & Canada) 5-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
DDR1026SD 价格&库存
很抱歉,暂时无法提供与“DDR1026SD”相匹配的价格&库存,您可以联系我们找货
