I-75142-306
Page 1 of 1
MOUNTING LOCATION:
Right side of radio cavity K R
TOOLS REQUIRED:
Dash Tool, Hook tool
Phillips screwdriver
HARDWARE INCLUDED:
(1)S7-1876 Mount
CELL PHONE & MEDIA MOUNT
INSTALLATION INSTRUCTIONS
PART#: 75142-306
MFG: KENWORTH
MODELS & YEARS:
T440, T470, C500, T600,
T660, T800, ICON900, W900
(06-22)
* * ADVISEMENT * *
Read instructions completely prior to
starting installation. All InDash Mounts
are designed so that after installation, phone
is facing normal driver position for lefthand drive vehicles. This mount is not
designed to be used in foreign countries
with right-hand drive vehicles. Use extreme
care when working around the plastic
components on the dash. Excess force, can
cause breakage of the plastic components.
STEP #1 With hook tool, remove the bezel that goes from the right of the radio,
gauges and switches all the way to the drivers door. There are a total of (13) clips
holding this bezel in place.
STEP #2 With Phillips screwdriver remove the upper right screw on center gauge
panel. Lift up the gauge panel and slide InDash by PanaVise Mount under panel and
over screw hole on upper right of gauges. Replace the screws, making sure the side
of the mount is flush with the dash before trying to put the bezel back in place.
STEP #3: Replace the bezel starting from the drivers door side and working to the
right side. The InDash by PanaVise Mount should be flush to the dash before the
bezel can be installed by the mount.
InDash installed under panel
INSTALLATION IS NOW COMPLETE. ENJOY YOUR NEW INDASH by PANAVISE MOUNT.
InDash installed showing location
06-09-21
There may be recent updates to this Instruction Sheet, please visit our website or contact PanaVise Products, Inc. for the latest revision as well as for the
most complete up-to-date PanaVise InDash Applications List: 7540 Colbert Dr., Reno, NV, Phone: 800.759.7535, 775.850.2900, Fax: 800.395.8002,
www.panavise.com. © 2018 PanaVise Products, Inc.
很抱歉,暂时无法提供与“75142-306”相匹配的价格&库存,您可以联系我们找货
