75107-311
75107-311
    PANAVISE
    HARDWARE
75107-311 数据手册
75107-311 Page 1 of 1 MOUNTING LOCATION: Right side of radio/display J R TOOLS REQUIRED: Dash Tool, Hook Tool Phillips Screwdriver HARDWARE INCLUDED: (2)-A-#8x9/16" Needle Pt Screw (2)-O- 8/32" Acorn Nuts (75001) CELL PHONE & MEDIA MOUNT INSTALLATION INSTRUCTIONS PART#: 75107-311 MFG: FORD MODELS & YEARS: F-150 2009-2012 * * ADVISEMENT * * Read instructions completely prior to starting installation. All InDash Mounts are designed so that after installation, phone is facing normal driver position for lefthand drive vehicles. This mount is not designed to be used in foreign countries with right-hand drive vehicles. Use extreme care when working around the plastic components on the dash. Excess force, can cause breakage of the plastic components. STEP #1: With Dash tool release the left side of the bezel to right of the Radio, that has the air vents, power outlet, and cubby. Pry with Dash Tool starting at the edge to the left of the cubby to release (1 or 2) clips. Continue up the edge to release as many left side clips as possible. Do not need to remove the bezel completely from the bottom. Just enough to get InDash Mount in place. See picture. STEP #2: Place the InDash by PanaVise Mount to the left of the power outlet cavity, and it straddles the clip slot and leaves space for the clip to be inserted all the way. Install the (2) screws into the dash with the Phillips Screwdriver. STEP #3: Sanp the bezel back in place securely. Install the Top part of the InDash by PanaVise Mount (75001) with the (2) Acorn nuts. Bottom part of InDash installed. Notice clip location. INSTALLATION IS NOW COMPLETE. ENJOY YOUR NEW INDASH by PANAVISE MOUNT. InDash installed showing location 10-23-12 There may be recent updates to this Instruction Sheet, please visit our website or contact PanaVise Products, Inc. for the latest revision as well as for the most complete up-to-date PanaVise InDash Applications List: 7540 Colbert Dr., Reno, NV, Phone: 800.759.7535, 775.850.2900, Fax: 800.395.8002, www.panavise.com. © 2002 PanaVise Products, Inc.
75107-311 价格&库存
很抱歉,暂时无法提供与“75107-311”相匹配的价格&库存,您可以联系我们找货
