75139-804
75139-804
    PANAVISE
    HARDWARE
75139-804 数据手册
I-75139-804 Page 1 of 1 MOUNTING LOCATION: Above center Air Vent V U TOOLS REQUIRED: T-25 Torx Driver Phillips Screwdriver PARTS INCLUDED: (1) S75139-804A BOTTOM (1)S75139-804B TOP '(1) S75006 TOP (2)8-32 Acorn Nuts (1) #8 x 9/16" Needle Pt. Screw CELL PHONE & MEDIA MOUNT INSTALLATION INSTRUCTIONS PART#: 75139-804 MFG: VOLVO MODELS & YEARS: Volvo Semi- VN & VT-Series 02-18 VHD 04-18 * * ADVISEMENT * * Read instructions completely prior to starting installation. All InDash Mounts are designed so that after installation, phone is facing normal driver position for lefthand drive vehicles. This mount is not designed to be used in foreign countries with right-hand drive vehicles. Use extreme care when working around the plastic components on the dash. Excess force, can cause breakage of the plastic components. STEP #1: Open cup holder at top of dash. With T-25 Torx Driver remove the (2) screws located under the cup holder openings. STEP #2: Lift up on the front of the bezel and tilt up the panel that includes the cup holder to release a total of (6) clips. Set panel aside. STEP #3: Place Part 75139-804 over the left side flat area and locate the left back screw of the bracket that holds the fuse panel in place. Remove this T-25 screw. Place the mount mounting hole over the screw hole, and replace the screw. The mount will come out just above the air vent. Make sure the mount fits well up to the front of the panel cavity, and that the slots for the clips of the bezel align to allow the top to fit in place. Install the (1) supplied Phillips Screw. T-25 Screw Locations STEP #4: Pick which mount Top you want to install according to the device you are installing. The top (2-A),with (1) bend fits in a North direction. And the part (75006) fits with the face going in a South direction. INSTALLATION IS NOW COMPLETE. ENJOY YOUR NEW INDASH by PANAVISE MOUNT. InDash installed showing North direction with 2-4 part Tilting and Removal of Top InDash installed showing South direction with 75006 part 09-30-2020 There may be recent updates to this Instruction Sheet, please visit our website or contact PanaVise Products, Inc. for the latest revision as well as for the most complete up-to-date PanaVise InDash Applications List: 7540 Colbert Dr., Reno, NV, Phone: 800.759.7535, 775.850.2900, Fax: 800.395.8002, www.panavise.com. © 2017 PanaVise Products, Inc.
75139-804 价格&库存
很抱歉,暂时无法提供与“75139-804”相匹配的价格&库存,您可以联系我们找货
