DDR1323S
DDR1323S
    TRIPPLITE
    TV DESK MNT SWIVEL 13" - 23"
DDR1323S 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Full-Motion Desk Mount for 13" to 27" FlatScreen Displays Highlights ● SEE NEW MODEL - DDR1327S ● Increases available desk/table space in office workstation applications ● Fits most flat-panel displays from 13” to 27” ● Convenient one-touch display adjustment for easy view optimization and improved ergonomics ● Full range of motion with -40° to +90° tilt, 180° swivel and 360° rotation capability ● Supports up to 20 lbs. ● 5-year warranty MODEL NUMBER: DDR1323S Description Tripp Lite’s sleekly designed, VESA-compliant DDR1323S Full-Motion Flat-Screen Desk Mount frees up valuable space in your workstation and allows you to re-position your display for increased viewing comfort and improved ergonomics. It features convenient one-touch display adjustment with tilt, swivel and rotation capabilities and fits most 13- to 27-inch flat-panel displays. Its durable, all-metal frame with soft, rubber feel finish withstands the stress of repeated use and blends easily into any décor. It comes with all necessary mounting hardware and supports weights of up to 20 lbs. For peace of mind, the DDR1323S comes backed by a 5-year warranty. Features ● Tripp Lite’s sleekly designed, VESA-compliant DDR1323S Full-Motion Flat-Screen Desk Mount frees up valuable space in your workstation and allows you to re-position your display for increased viewing comfort and improved ergonomics ● Convenient one-touch display adjustment with tilt, swivel and rotation capabilities and fits most 13- to 27-inch flat-panel displays ● Durable, all-metal frame with soft, rubber feel finish withstands the stress of repeated use and blends easily into any décor ● Includes all necessary mounting hardware and supports weights of up to 20 lbs ● 5-year warranty Specifications OVERVIEW UPC Code 037332178701 PHYSICAL Color Black Material of Construction Metal VESA Pattern (mm) 75x75; 100x100 Motion Full Mounting Location Desktop Degrees of Motion -40/+90 Tilt; 180 Swivel; 360 Rotate Maximum Weight Capacity (lbs.) 20 Maximum Weight Capacity (kg) 9 Min/Max Arm Extension (in.) 19.68 Min/Max Arm Extension (cm) 50 Shipping Dimensions (hwd / in.) 5.39 x 15.79 x 16.73 1/2 Package Includes ● DDR1323S Full-Motion FlatScreen Desk Mount ● Mounting Hardware ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 13.69 x 40.11 x 42.49 Shipping Weight (lbs.) 11.55 Shipping Weight (kg) 5.24 Unit Dimensions (hwd / in.) 20.070 x 6.300 x 23.700 Unit Weight (lbs.) 11.55 Unit Weight (kg) 5.24 FEATURES & SPECIFICATIONS Cord Management Yes Tools Necessary Yes WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty Product Warranty Period (U.S. & Canada) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
DDR1323S 价格&库存
很抱歉,暂时无法提供与“DDR1323S”相匹配的价格&库存,您可以联系我们找货
