75051
75051
    GEEHY(极海半导体)
    WASHER SEALING M5 STN STEEL
75051 数据手册
SEELOC® Washers Self-Sealing Washers from APM Page 1 of 3 Customer Login Find Reps & Distributors Product Details Government Sales APM Product Search Self-Sealing Washers :: Washers APM Part Number Search Mfr. Part Compatibility Search NSN Cross Reference SEELOC® Washers Availability: In-Stock: Inch & Metric METRIC SIZES Part No. Thread Size Washer O.D. Max. Hole Size (mm) 74301 M3 12.7 mm 6.35 74401 M4 12.7 mm 6.35 74501 M5 12.7 mm 6.35 74302 M3 25.4 mm 9.53 74402 M4 25.4 mm 15.87 74502 M5 25.4 mm 15.87 74602 M6 25.4 mm 15.87 INCH SIZES Part No. Thread Size Washer O.D. Max. Hole Size (in/mm) 75601 #6 1/2" 1/4 / 6.35 75801 #8 1/2" 1/4 / 6.35 75101 #10 1/2" 1/4 / 6.35 75602 #6 1" 3/8 / 9.53 75802 #8 1" 5/8 / 15.87 75102 #10 1" 5/8 / 15.87 75082 1/4 1" 5/8 / 15.87 75107 5/16 1" 5/8 / 15.87 75122 3/8 1" 5/8 / 15.87 75142 7/16 1" 5/8 / 15.87 75162 1/2 1" 5/8 / 15.87 1/2 / 12.7 75603 #6 1-1/2" 75803 #8 1-1/2" 1 / 25.4 75103 #10 1-1/2" 1 / 25.4 75083 1/4 1-1/2" 1 / 25.4 75108 5/16 1-1/2" 1 / 25.4 http://www.apmhexseal.com/ProdSearch_details.aspx?PID=33 2/29/2012 SEELOC® Washers Self-Sealing Washers from APM Page 2 of 3 75123 3/8 1-1/2" 75143 7/16 1-1/2" 1 / 25.4 1 / 25.4 75163 1/2 1-1/2" 1 / 25.4 SEELOC® Air & water-tight self-sealing washers SEELOC® Washers are self-sealing, vibration-resistant washers, each having a silicone rubber section, molded and bonded to a stainless steel formed washer. These washers are designed for use with regular screws, bolts, or studs for sealing panels and enclosures having standard as well as large clearance holes or adjustment slots, and can also be used to seal openings of protrusions. Upon tightening, a seal is formed under the head of the fastener as well as around the periphery of the washer face. SEELOC® SPECIFICATIONS Material: Standard Seeloc® washer is stainless steel, but can be made in carbon steel, nickel-plated brass, aluminum, etc. Silicone rubber is standard. (For other materials choices see Elastomeric Chart.) Temperature Range: -160°F to +500°F (-106°C to +260°C) Pressure Range: Exceeds 100 psi internal and external. Shelf Life: Excess of 25 years. Resistant to: Salt water, acids, weather, sunlight, ozone, etc. Installation: Seeloc® washers are installed on bolts, screws, or studs in the same manner as regular washers. The rubber section should always face the panel. Rating: IP66/68. UL Recognized for Type 4X & Type 6 enclosure protection. Login to Access Dimensional Drawings & CAD files Back to Results About APM's Sealing Boots Division: The Electronics Division of APM HEXSEAL develops and manufactures environmental protection sealing components for controls that are mounted on switches, potentiometers, encoders, and circuit breakers. Using advanced elastomer molding technology, a broad range of sealing boots are produced to match most controls manufactures’ standard part numbers. Most are IP66/68 ingress protection rated and UL recognized. About APM's Self-Sealing Fastener Division: The APM line of high-pressure, reusable, self-sealing fasteners includes self- http://www.apmhexseal.com/ProdSearch_details.aspx?PID=33 2/29/2012 SEELOC® Washers Self-Sealing Washers from APM Page 3 of 3 sealing screws, self-sealing locking nuts, self-sealing locking bolts, self-sealing rivets, and self-sealing washers all designed to seal in/out air, water, lubricants and other liquid or gaseous contaminants. Home : Product Lines : Tech Info and FAQs : About APM : Find Reps & Distributors : Contact Us : Site Map Switch & Circuit Breaker Boots Self-Sealing Fasteners & Washers Contact Us Switch & Potentiometer Boots SEELSKREW® Self-Sealing Screws IQ Series Boots SEELBOLT® Self-Sealing Bolts Toll Free: 800.498.9034 eMail: info@apmhexseal.com Circuit Breaker Boots SEELNUT® Self-Sealing Nuts Custom Elastomeric Molding SEELRIVET® Self-Sealing Rivets Colorizing Lamp Filters SEELOC® WASHER Self-Sealing & SelfLocking Washers HEXSEAL®, SEELSKREW®. SEELBOLT®, SEELNUT®, SEELRIVET®, SEELOC® are registered trademarks of APM Corp. website design by gravitate by design http://www.apmhexseal.com/ProdSearch_details.aspx?PID=33 © 2011 APM Corp. All Rights Reserved. 2/29/2012
75051 价格&库存
很抱歉,暂时无法提供与“75051”相匹配的价格&库存,您可以联系我们找货
