The Lead-Free Zone Attention Sign provides identification for areas that are leadfree. It features the English language on one side, and Spanish on the opposite
side. It is constructed of durable and colorful green and white high-impact plastic
which can be easily seen and recognized. The sign provides a tie-in with other
lead-free work area products.
Property
Test Method
Units
Value
Specific Gravity
D-1505
1.35±.01
Gauge Tolerance
Hand Micrometer
±5%
Yield (normal)
in^2/lb
26 mil (790±40)
24 mil (856±40)
10 mil (2055±100)
Item
Description
47104 Attention Sign, Lead-Free Zone
Made in America
Size
4” x 10'
Flex Resistance
(Embossed & Overload)
Arthur Little
(30 mil) flexes
4000 minimum
Embossed Character
Retention
6hrs/150°F Water
mils drop
4 maximum
Laminating Temperature
*F
270-310+(estimate)
Slit Width Tolerance
Metric Ruler
mm
±1 (~±1/32")
Sheet Size Tolerance
Metric Ruler
mm
±1 (~±1/32")
Roughness (RA)
Perthometer
Microinches
Custimized from 50-140
Peak Density
Perthometer
# Above 100
Microinches/cm
Customized from 50-140
Printability
All Methods
Excellent
Sealability
All standard
methods
Excellent
Gloss (85*)
D-523
3±3
Heat Deflection
Temperature
D-648 (264 psi)
*F
140±4
Cold Heat Temperature
D-1790
*C
-20
Tensile Impact Stg.
D-53488
ft/lb/in^2
275±40
Elongation (at break)
D-882
180±20
Tensile Stg. (at yield)
D-882
lb/in^2
6550±650
ATTENTION SIGN, BI-LINGUAL, LEAD-FREE ZONE, 4" x 10"
PROTEKTIVE PAK
13520 MONTE VISTA AVENUE, CHINO, CA 91710
PHONE (909) 627-2578, FAX (909) 363-7331
ProtektivePak.com
©2006 DESCO INDUSTRIES INC.
Employee Owned
DRAWING NUMBER
47104
DATE:
5/06
很抱歉,暂时无法提供与“47104”相匹配的价格&库存,您可以联系我们找货
