COLOR*:
Yellow with black printing
*Color and texture may vary between lots.
SYMBOL:
Made in the
United States of America
Symbol is ESD Association ESD Protective symbol per
ANSI/ESD S8.1
PACKAGED: 1,000 per roll, 3" diameter core, Date/Lot Coded for QC Traceability
Desco’s ESD protective symbol labels are designed to identify that the labeled item is
an ESD protective ESD control product. The ESD protective Symbol Label is 1 inch by
1 inch with 1,000 label per roll (3 inch paper core).
1"
The Desco 06713 Labels have a permanent adhesive and the label will tear when
removed to indicate tampering. Labels with permanent adhesive can not be reused.
Labels are coated with varnish for added durability and resistance to moisture, grease,
and alcohol.
PAPER SPECIFICATIONS:
Facestock:
60# SemiGloss Litho
Adhesive:
Tamper Evident Adhesive (06713)
Liner:
40# RL
1"
Per Symbols standard ANSI/ESD S8.1 “The ESD protective symbol differs from the ESD susceptibility
symbol, by the addition of an arc around the outside of the triangle and the omission of the slash across the
hand and the triangle.” “The ESD protective symbol should be used to identify items that are specifically
designed to provide ESD protection for ESDS [ESD sensitive] assemblies and devices. Examples of these
are packaging, ESD protective clothing and personnel grounding equipment. The ESD protective symbol
should also be used on items designed to replace static generative materials. Examples of these items are
ESD protective work station equipment, trash can liners, and chairs. The item is to be ESD protective or nonstatic generative by design.”
Item
Description
Qty/Roll
06713
1" x 1"
1,000
RoHS 2 and REACH Compliance Statement
None of the RoHS 2 restricted materials or REACH substances of very high concern as of 2013/06/20
are intentionally added in manufacturing this product. Ref: European Union Directive 2011/65/EU and
Regulation (EC) No. 1907/2006/CE. See Desco Limited Warranty at Desco.com.
Unless otherwise noted, tolerance is ± 10%
Specifications and procedures subject to change without notice.
LABEL, ESD PROTECTIVE SYMBOL
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370
© 2013 DESCO INDUSTRIES INC.
Employee Owned
DRAWING
NUMBER
06713
DATE:
August
2013
很抱歉,暂时无法提供与“06713”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+94.114981+12.18221
