COLOR:
Yellow with black printing
SYMBOL:
RS-471, Symbol is same as ESD Association ESD
Susceptibility symbol per ANSI/ESD S8.1
Made in the
United States of America
PACKAGED: 500 per roll, 3" diameter core, Date/Lot Coded for QC Traceability
Pressure sensitive labels are designed to call immediate attention to items that
are susceptible to damage from ESD. Permanent and reusable adhesive labels
are designed for use on packages, containers, and anywhere a permanent or
removeable and reusable warning is required. Labels are coated with varnish for
added durability.
PAPER SPECIFICATIONS:
Facestock:
60# SemiGloss Litho
Adhesive:
B-82 - Removeable and Reusable
B-82 - Permanent
Liner:
40# RL
INK & VARNISH SPECIFICATIONS:
Water Resistance:
Excellent
Grease Resistance:
Excellent
Alcohol Resistance:
Excellent
Item
Description
Qty/Roll
47500
2" x 2"
500
47507
2" x 2", Re-usable
500
RoHS Compliance Statement
None of the following materials are intentionally added in
manufacturing this product: lead, mercury, cadmium, hexavalent
chromium, polybrominated biphenyls (PBB) or polybrominated
diphenyl ethers (PBDE) as outlined in the Directive 2002/95/
EC Article 4.1. See Desco Industries Inc. letter on-line at
ProtektivePak.com.
Per ANSI/ESD S8.1 section 3.1 ESD Susceptibility Symbol Application states 1 “The
ESD susceptibility symbol should be used on assemblies and devices that have a
sensitivity to ESD events.” and, “The symbol may be incorporated on a sticker used to
close or seal ESD protective packaging to indicated that materials inside the package
are ESD susceptible.
Unless otherwise noted, tolerance is ± 10%
Specifications and procedures subject to change without notice.
LABEL, SUSCEPTIBILITY, RS-471
PROTEKTIVE PAK
13520 MONTE VISTA AVENUE, CHINO, CA 91710
PHONE (909) 627-2578, FAX (909) 363-7331
ProtektivePak.com
© 2011 DESCO INDUSTRIES INC.
Employee Owned
DRAWING NUMBER
47500
DATE:
November
2011
很抱歉,暂时无法提供与“47500”相匹配的价格&库存,您可以联系我们找货
