technical specification - LP series:
MODEL
0.5 – 1 – 2 – 5W
Xenon Beacons
2 – 5W
Xenon Beacons
Cyan Plate
Magenta Plate
Yellow Plate
Black Plate
Xenon Beacons
VOLTAGE
LP1X12/0.5
12
LP1XMV/0.5
MULTI
LP1X06/1
LP1X12/1
LP1X24/1
6
12
24
LP1XMV/1
MULTI
LP1X12/2
LP1X24/2
LP1X24/2ac
LP1X50/2
LP1X110/2ac
LP1X230/2ac
12
24
24ac
50
110ac
230ac
LP4XMV/2
MULTI
LP3X12/5 Sync
LP3X24/5 Sync
LP4XMV/5
12
24
MULTI
VOLTAGE
RANGE
10 - 15 Vdc
10 - 100 Vdc
20 - 72 Vac
4.7 - 7.5 Vdc
10 - 15 Vdc
20 - 30 Vdc
10 - 100 Vdc
20 - 72 Vac
10-15 Vdc
20 - 30 Vdc
20 - 30 Vac
40 - 55 Vdc
90 - 125 Vac
207 - 253 Vac
10 - 100 Vdc
20 - 72 Vac
10 - 15 Vdc
20 - 30 Vdc
10 - 100 Vdc
20 - 72 Vac
POWER
OUTPUT
0.5W
@6V
CURRENT CONSUMPTION (mA)
@12V
@24V
@50V
@100V
50
FLASH
RATE
60/MIN
0.5W
60
37
30
60/MIN
1W
1W
1W
240
115
55
60/MIN
60/MIN
60/MIN
1W
112
63
50
29
60/MIN
2W
2W
2W
2W
2W
2W
220
110
100
55
60/MIN
60/MIN
60/MIN
60/MIN
60/MIN
60/MIN
2W
130
95
83
37
75/MIN
5W
5W
360
160
90/MIN
90/MIN
5W
250
200
112
60
75/MIN
technical specification - LT series:
150gsm gloss art
MODEL
Fire
Industrial
Security
Low current consumption
Available in 6, 12, 24, 50, 110 and 230V versions
VOLTAGE
LT4XMV/2
MULTI
LT2X06/5
LT3X12/5
LT3X24/5
LT2X50/5
LT3X110/5ac
LT3X230/5ac
6
12
24
50
110ac
230ac
LT4XMV/5
MULTI
VOLTAGE
RANGE
10 - 100 Vdc
20 - 72 Vac
4 - 7 Vdc
10 - 15 Vdc
20 - 30 Vdc
40 - 60 Vdc
90 - 125 Vac
207 - 253 Vdc
10 - 100 Vdc
20 - 72 Vac
POWER
OUTPUT
@6V
@12V
@24V
@50V
@100V
FLASH
RATE
2W
130
95
83
37
75/MIN
5W
5W
5W
5W
5W
5W
1000
360
160
100
120/MIN
90/MIN
90/MIN
120/MIN
90/MIN
90/MIN
5W
255
190
112
70
75/MIN
100%
Multivoltage option (10 - 100Vdc, 20 - 72Vac)
Completely weatherproof to IP67 (when installed)
High efficiency
360° visibility
12 months guarantee ~ 5 years in intruder alarm systems (LP)
materials:
accessories:
Polycarbonate Lens on 110V, 230V and Multivoltage.
Others high impact acrylic.
A range of accessories is available for both beacons.
Please see separate Accessories Leaflet.
High impact polystyrene base.
lens colours:
Clear, Amber, Red, Blue or Green.
. . simply brilliant
High voltage transient and
polarity reversal protection fitted.
CE - Complies with EMC Directive
89/336/EEC and Low Voltage
Directive 73/23/EEC, where
appropriate.
Y
MY
M
CM
C
CY
CMY
K
MODEL
0.5 – 1 – 2 – 5W
Xenon Beacons
2 – 5W
Xenon Beacons
Cyan Plate
Magenta Plate
Yellow Plate
Black Plate
Xenon Beacons
VOLTAGE
LP1X12/0.5
12
LP1XMV/0.5
MULTI
LP1X06/1
LP1X12/1
LP1X24/1
6
12
24
LP1XMV/1
MULTI
LP1X12/2
LP1X24/2
LP1X24/2ac
LP1X50/2
LP1X110/2ac
LP1X230/2ac
12
24
24ac
50
110ac
230ac
LP4XMV/2
MULTI
LP3X12/5 Sync
LP3X24/5 Sync
LP4XMV/5
12
24
MULTI
VOLTAGE
RANGE
10 - 15 Vdc
10 - 100 Vdc
20 - 72 Vac
4.7 - 7.5 Vdc
10 - 15 Vdc
20 - 30 Vdc
10 - 100 Vdc
20 - 72 Vac
10-15 Vdc
20 - 30 Vdc
20 - 30 Vac
40 - 55 Vdc
90 - 125 Vac
207 - 253 Vac
10 - 100 Vdc
20 - 72 Vac
10 - 15 Vdc
20 - 30 Vdc
10 - 100 Vdc
20 - 72 Vac
POWER
OUTPUT
0.5W
@6V
@12V
@24V
@50V
@100V
50
FLASH
RATE
60/MIN
0.5W
60
37
30
60/MIN
1W
1W
1W
240
115
55
60/MIN
60/MIN
60/MIN
1W
112
63
50
29
60/MIN
2W
2W
2W
2W
2W
2W
220
110
100
55
60/MIN
60/MIN
60/MIN
60/MIN
60/MIN
60/MIN
2W
130
95
83
37
75/MIN
5W
5W
360
160
90/MIN
90/MIN
5W
250
200
112
60
75/MIN
150gsm gloss art
MODEL
Fire
Industrial
Security
VOLTAGE
LT4XMV/2
MULTI
LT2X06/5
LT3X12/5
LT3X24/5
LT2X50/5
LT3X110/5ac
LT3X230/5ac
6
12
24
50
110ac
230ac
LT4XMV/5
MULTI
VOLTAGE
RANGE
10 - 100 Vdc
20 - 72 Vac
4 - 7 Vdc
10 - 15 Vdc
20 - 30 Vdc
40 - 60 Vdc
90 - 125 Vac
207 - 253 Vdc
10 - 100 Vdc
20 - 72 Vac
POWER
OUTPUT
@6V
@12V
@24V
@50V
@100V
FLASH
RATE
2W
130
95
83
37
75/MIN
5W
5W
5W
5W
5W
5W
1000
360
160
100
120/MIN
90/MIN
90/MIN
120/MIN
90/MIN
90/MIN
5W
255
190
112
70
75/MIN
100%
High efficiency
360° visibility
materials:
accessories:
lens colours:
appropriate.
Y
MY
M
CM
C
CY
CMY
K
很抱歉,暂时无法提供与“06730”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+167.606291+21.74678
