47507
47507
    DESCO
    SIGN ESD/STATIC WARN 2"X2" 500PC
47507 数据手册
COLOR: Yellow with black printing SYMBOL: RS-471, Symbol is same as ESD Association ESD Susceptibility symbol per ANSI/ESD S8.1 Made in the United States of America PACKAGED: 500 per roll, 3" diameter core, Date/Lot Coded for QC Traceability Pressure sensitive labels are designed to call immediate attention to items that are susceptible to damage from ESD. Permanent and reusable adhesive labels are designed for use on packages, containers, and anywhere a permanent or removeable and reusable warning is required. Labels are coated with varnish for added durability. PAPER SPECIFICATIONS: Facestock: 60# SemiGloss Litho Adhesive: B-82 - Removeable and Reusable B-82 - Permanent Liner: 40# RL INK & VARNISH SPECIFICATIONS: Water Resistance: Excellent Grease Resistance: Excellent Alcohol Resistance: Excellent Item Description Qty/Roll 47500 2" x 2" 500 47507 2" x 2", Re-usable 500 RoHS Compliance Statement None of the following materials are intentionally added in manufacturing this product: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE) as outlined in the Directive 2002/95/ EC Article 4.1. See Desco Industries Inc. letter on-line at ProtektivePak.com. Per ANSI/ESD S8.1 section 3.1 ESD Susceptibility Symbol Application states 1 “The ESD susceptibility symbol should be used on assemblies and devices that have a sensitivity to ESD events.” and, “The symbol may be incorporated on a sticker used to close or seal ESD protective packaging to indicated that materials inside the package are ESD susceptible. Unless otherwise noted, tolerance is ± 10% Specifications and procedures subject to change without notice. LABEL, SUSCEPTIBILITY, RS-471 PROTEKTIVE PAK 13520 MONTE VISTA AVENUE, CHINO, CA 91710 PHONE (909) 627-2578, FAX (909) 363-7331 ProtektivePak.com © 2011 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 47500 DATE: November 2011
47507 价格&库存
很抱歉,暂时无法提供与“47507”相匹配的价格&库存,您可以联系我们找货
