06770
06770
    DESCO
    SIGN ESD/STATIC 2"X0.75" 500PC
06770 数据手册
COLOR: CAUTION PACKAGED: 500 per roll, 3" diameter core, Date/Lot Coded for QC Traceability CONTAINS PARTS AND ASSEMBLIES SUSCEPTIBLE TO DAMAGE BY ELECTROSTATIC DISCHARGE (ESD) Item # 06770 Yellow with black printing Pressure sensitive labels are designed to call immediate attention to items that are susceptible to damage from ESD. The permanent adhesive labels are designed for use on packages, containers, and anywhere a permanent warning is required. Labels are coated with varnish for added durability. descoindustries.com Warns repair people that ESD precautions are required when opening. MIL-STD-1686C states “Equipment containing ESDS parts and assemblies shall be marked with the (ESD susceptibility) symbol. The symbol shall be located on the exterior surface of the equipment and readily visible to personnel prior to gaining access to ESDS parts and assemblies within the equipment. The following ESD caution statement should be paced adjacent to the RS-471 symbol: “CAUTION, CONTAINS PARTS AND ASSEMBLIES SUSCEPTIBLE TO DAMAGE BY ELECTROSTATIC DISCHARGE (ESD).” (Ref. paragraph 5.7.2) Per ANSI/ESD S8.1 section 3.1 ESD Susceptibility Symbol Application states 1 “The ESD susceptibility symbol should be used on assemblies and devices that have a sensitivity to ESD events.” and, “The symbol may be incorporated on a sticker used to close or seal ESD protective packaging to indicate that materials inside the package are ESD susceptible. Per ANSI/ESD S20.20 Paragraph 6.2.5.1. ESDS Assemblies and Equipment “ESDS assemblies and equipment containing ESDS parts and assemblies should be marked with an ESD caution symbol located in a position readily visible when an ESDS assembly is incorporated into its next higher assembly.” The user must determine the suitability for use of a Label for his particular application. For best results, Label inventory should be continually replenished. It is recommended that rolls of Labels be stored flat and rotated (flipped over to the other side) periodically. Label rolls should be stored in a dry, well ventilated room with a reasonably consistent temperature of 68°F (20°C) and be protected from exposure to direct sunlight. Labels should not be stored in ultraviolet sunlight, moisture, or heat. PAPER SPECIFICATIONS: Facestock: 60# SemiGloss Litho Adhesive: B-82 Liner: 40# RL INK & VARNISH SPECIFICATIONS: Water Resistance: Excellent Grease Resistance: Excellent Alcohol Resistance: Excellent Item 06770 Description 3/4" x 2" Qty/Roll 500 RoHS Compliance Statement None of the following materials are intentionally added in manufacturing this product: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE) as outlined in the Directive 2002/95/EC Article 4.1. See Desco Industries Inc. letter on-line at Desco.com. Unless otherwise noted, tolerance is ± 10% Specifications and procedures subject to change without notice. Label rolls over one year old should be evaluated by the user to determine acceptability for the user’s application. Desco Industries, Inc. recommends those tracking useful life of product to use shipping/ invoice date as Desco Industries, Inc. expressly warrants that for a period of one (1) year from the date of purchase, Desco Labels will be free of defects in material (parts) and workmanship (labor). See details of Limited Warranty online at Desco.com/Warranty.aspx Made in the United States of America LABEL, EQUIPMENT CONTAINING DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 ©2021 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 06770 DATE: June 2021
06770
物料型号:06770
器件简介:这些是压力敏感的警示标签,设计用于提醒人们注意物品可能因静电放电(ESD)而受损。标签适用于包装、容器以及需要永久警告的地方。标签涂有清漆以增强耐用性。
引脚分配:文档中没有提到引脚分配,因为它不是电子元件,而是一张标签。
参数特性: - 颜色:黄色,带有黑色印刷。 - 规格:3/4"x2",每卷500张。 - 材料:面材60#半光胶印B-82,底纸40# RL。 - 胶粘剂:符合MIL-STD-1686C标准,具有优秀的耐水性、耐油脂性和耐醇性。
功能详解: - 根据ANSI/ESD S8.1第3.1节,ESD敏感性符号应用于对ESD事件敏感的组装和设备。 - 根据ANSI/ESD S20.20第6.2.5.1节,含有ESD敏感部件和组装的ESDS组装和设备应在其被整合到下一个更高级别组装时容易看到的位置标记ESD警示符号。
应用信息: - 这些标签用于警告维修人员在打开时需要采取ESD预防措施。 - 用户必须确定标签对其特定应用的适用性。 - 推荐存储条件为干燥、通风良好的房间,温度保持在20°C,避免阳光直射。
封装信息:每卷标签500张,卷径3英寸,具有日期/批号以实现质量控制追溯。
合规性声明:产品制造过程中没有故意添加铅、汞、镉、六价铬、多溴联苯(PBB)或多溴二苯醚(PBDE),符合2002/95/EC指令第4.1条。
规格和程序:如有变更,恕不另行通知。除非另有说明,公差为±10%。
有效期:标签卷超过一年应由用户评估以确定是否适用于其应用。Desco Industries, Inc.保证自购买之日起一年内,Desco标签在材料(部件)和工艺(劳动)上无缺陷。
制造信息:美国制造
联系信息:Desco West和Desco East的地址、网站、电话和传真号码。
图纸日期和编号:2021年6月06770
06770 价格&库存
很抱歉,暂时无法提供与“06770”相匹配的价格&库存,您可以联系我们找货
