CF42SC1MM
CF42SC1MM
    AEARO
    CONFORCF42SC1.0MMTX5"X7"
CF42SC1MM 数据手册
Electronic Materials Brochure TABLE OF CONTENTS 3 Introduction to Materials 4 ISODAMP™ C-8000 Materials 6 ISOLOSS™­­­­ SL Molding Materials Thermosets 8 CONFOR™ EG Foams 10 CONFOR™ SC Foams ISODAMP ™ C-8000 MATERIALS • Highly damped thermoplastic molded products for noise, shock and vibration control • RoHS compliant • JIG-101 compliant • Non-halogenated • Listed UL 94 V-0 flame rating • Available in durometers from 40 to 88 Type A ISOLOSS™ SL MATERIALS • Highly damped thermoset molded products for noise, shock and vibration control • RoHS compliant • JIG-101 compliant • Non-halogenated • Available in durometers from 20 to 60 Type A • Available in listed UL 94 and non-listed formulations CONFOR™ EG FOAMS • Highly compliant shock and energy absorbing, strain-rate sensitive, open-cell foam products • Listed UL 94 HF-1 flame rating • RoHS compliant • JIG-101 compliant • Non-halogenated • Available in a range of stiffnesses and parts CONFOR™ SC FOAMS • Small cell, slow-recovery foam that can be easily compressed up to 95% for shock protection and gasketing in tight spaces. • Low compression set • Highly comformable gap filler • Listed HF-1 @ 0.5mm-3.0mm • RoHS Compliant and non-halogenated • JIG-101 Compliant ISODAMP™ C-8000 Molding Materials Typical Properties Property C-8012 C-8002 C-8070 C-8130 Description Hardness ASTM D2240 Type A Durometer 23C (73F) 15 sec impact Compression Load Deflection kPa (psi) ASTM D575 at 0.51 cm/min (0.2 in/min) 10% kPa (psi) 20% kPa (psi) 30% kPa (psi) Compression Set (%) ASTM D395 Method B 22 hr at 22C (72F) 22 hr at 70C (158F) Tensile Strength kPa (psi) ASTM D412 Tear Strength kN/m (lbf/in) ASTM D624 Temperature Range C (F) Peak Damping Performance Temperature Range @ 10 Hz @ 100 Hz @ 1000 Hz TPE Solid TPE Solid TPE Solid TPE Solid Thermoplastic Thermoplastic Thermoplastic Thermoplastic 40 51 70 88 324 (47) 627 (91) 958 (139) 455 (66) 883 (128) 1358 (197) 951 (138) 1799 (261) 2799 (406) 3619 (525) 6494 (942) 9087 (1318) 12 15 15 35 100 99 98 90 3309 5309 10059 11279 (480) (770) (1459) (1636) 18 25 50 72 (100) (141) (285) (410) -26 to 22 -19 to 35 -13 to 55 -6 to 37 -2 to 50 4 to 71 4 to 42 8 to 53 14 to 68 5 to 27 10 to 34 16 to 41 The above technical information and data should be considered representative or typical only and should not be used for specification purpose. Environmental Properties Property Flammability UL 94 C-8012 C-8002 C-8070 C-8130 Listed V-0 @ 6 mm (0.24in) RoHS Compliant Halogen Free* Listed V-0 @ 3.4 mm (0.13 in) Meets V-0 @ 3.2mm (0.125 in) Listed V-0 @ 3.5 mm (0.14 in) Yes Yes Yes Yes Yes Yes Yes Yes Halogen-free per IEC 61249-2-21. www.earshockandvibe.com solutions@earsc.com Toll-free hotline ­­ 7911 Zionsville Road (877) EAR-IDEA (327-4332) Rm. 807, 8/F, B Area Indianapolis, IN 46268 Phone (651) 575-0151 Zhongtianyuan Logistics Center Taohua Rd. Shenzhen, China (P.R.C.) Phone: 86-755-8348-5522 Fax (317) 982-3401 Futian Free Trade Zone Fax: 86-755-8348-5533 ©2014 Aearo Technologies • Printed 9.16 40 30 20 10 0 -10°C 40 20 10 0 -10 -20 -30°C 10000 1000 1.E+03 1000 1.E+02 100 1.E+02 100 1.E+01 10 1.E+01 10 Shear Modulus (MPa)/(Loss Factor) Shear Modulus (MPa) / (Loss Factor) 1.E+03 (1.0) 1.E+00 1.E-01 1.00E-05 1.00E-03 1.00E-01 1.00E+01 1.00E+03 1.00E+05 Reduced (Hz) Reduced Frequency Frequency (Hz) 1.00E+07 1.00E+09 1.00E+11 (1.0) 1 1.E+00 (0.1) 0.1 1.E-01 1.00E-04 (0.1) 1 1.00E-02 1.00E+00 1.00E+02 60 50 40 30 20 10 0 -10°C 10000 1000 1.E+02 (1.0) 100 1.E+01 (0.1) 10 1.00E-03 1.00E-01 1.00E+01 1.00E+03 1.00E+05 1.00E+07 Reduced Frequency (Hz) Reduced Frequency (Hz) www.earshockandvibe.com solutions@earsc.com 1.00E+09 1.00E+11 80 1.E+04 Frequency (Hz) Frequency (Hz) 1.E+03 1.E+00 1.00E-05 1.00E+08 1.00E+10 0.1 1.00E+12 May 13, 2013 - Orig 1 ­­ 7911 Zionsville Road (877) EAR-IDEA (327-4332) Rm. 807, 8/F, B Area 60 50 40 30 20 10 0 10000 1000 1.E+02 100 1.E+01 10 (1.0) (0.1) 1.E+00 1.00E-06 1.00E-04 1.00E-02 1.00E+00 1.00E+02 1.00E+04 1.00E+06 1.00E+08 Reduced Frequency (Hz) Reduced Frequency (Hz) Indianapolis, IN 46268 -10°C 1.E+03 May 29, 2013 - Preliminary Toll-free hotline 70 (Hz) 70 1.00E+06 ISODAMP C-8130 Isodamp C-8130 Shear Modulus (MPa) /(MPa)/(Loss (Loss Factor) Factor) Shear Modulus 80 1.E+04 1.00E+04 Reduced (Hz) ReducedFrequency Frequency (Hz) May 13, 2013 - Orig ISODAMP C-8070 Isodamp C-8070 Shear Modulus (MPa) / Loss FactorFactor) Shear Modulus (MPa)/(Loss 30 1.E+04 Frequency (Hz) Frequency (Hz) Shear Modulus (MPa)/(Loss Factor) Shear Modulus (MPa) / (Loss Factor) 50 10000 1.E+04 Phone (651) 575-0151 Zhongtianyuan Logistics Center Taohua Rd. Shenzhen, China (P.R.C.) Phone: 86-755-8348-5522 May 13, 2013 - Orig Fax (317) 982-3401 Futian Free Trade Zone Fax: 86-755-8348-5533 ©2014 Aearo Technologies • Printed 9.16 1 1.00E+10 Frequency Frequency (Hz) 80 70 60 Isodamp C-8012 ISODAMP C-8012 Frequency Frequency(Hz) (Hz) Isodamp C-8002 ISODAMP C-8002 ISOLOSS™ Molding Materials - Thermosets Typical Properties Property SL-20300 SL-35300 SL-50300 SL-60300 Description Synthetic Synthetic Synthetic Synthetic Rubber Rubber Rubber Rubber Hardness ASTM D2240 Type A Durometer 23C (73F) 15 sec impact 19 30 45 56 Compression Load Deflection kPa (psi) ASTM D575 at 0.51 cm/min (0.2 in/min) 10% kPa (psi) 117 (17) 193 (28) 338 (49) 517 (68) 20% kPa (psi) 221 (32) 379 (55) 669 (97) 1013 (132) 30% kPa (psi) 352 (51) 607 (88) 1096 (159) 1689 (222) Compression Set (%) ASTM D395 Method B 22 hr at 22C (72F) 3 4 2 3 22 hr at 70C (158F) 7 6 7 4 Tensile Strength kPa (psi) 4185 5667 10149 10721 ASTM D412 (600) (822) (1472) (1555) Tear Strength kN/m (lbf/in) 11.4 20.1 18.9 24.15 ASTM D624 (65) (115) (108) (138) Temperature Range C Peak Damping Performance Temperature Range @ 10 Hz -23 to 29 -21 to 30 -5 to 42 -10 to 35 @ 100 Hz -18 to 47 -16 to 47 -2 to 63 -4 to 47 @ 1000 Hz -14 to 71 -12 to 72 4 to 82 1 to 60 The above technical information and data should be considered representative or typical only and should not be used for specification purpose. Environmental Properties Property Flammability UL 94 RoHS Compliant Halogen Free* SL-20300 SL-35300 SL-50300 SL-60300 Listed HB @ 2.3mm-2.5mm Listed HB @ 3.0mm Listed HB @ 3.0mm Listed HB @ 3.0mm Yes Yes Yes Yes Yes Yes Yes Yes *Halogen-free per IEC 61249-2-21. www.earshockandvibe.com solutions@earsc.com Toll-free hotline ­­ 7911 Zionsville Road (877) EAR-IDEA (327-4332) Rm. 807, 8/F, B Area Indianapolis, IN 46268 Phone (651) 575-0151 Zhongtianyuan Logistics Center Taohua Rd. Shenzhen, China (P.R.C.) Phone: 86-755-8348-5522 Fax (317) 982-3401 Futian Free Trade Zone Fax: 86-755-8348-5533 ©2014 Aearo Technologies • Printed 9.16 40 30 20 10 0 -10 -20 °C 70 30 20 10 0 -10 -20°C 1.E+03 1000 1.E+02 100 1.E+02 100 1.E+01 (1.0) 10 1.E+01 10 1.E+00 (0.1) 1 1.E+00 1 1.00E-02 1.00E+00 1.00E+02 1.00E+04 1.00E+06 1.00E+08 Reduced Frequency (Hz) Shear Modulus (MPa)/(Loss Factor) Shear Modulus (MPa) / (Loss Factor) 1000 Reduced Frequency (Hz) (0.1) 0.1 1.00E+12 1.00E+10 80 70 60 1.E+04 50 40 30 20 1.E-01 1.00E-04 1.00E-02 1.00E+00 10 0 -10° C 1 1.00E+03 1.00E+05 1.00E+07 Reduced Frequency (Hz) Reduced Frequency (Hz) www.earshockandvibe.com solutions@earsc.com 1.00E+09 Shear Modulus (MPa) / (Loss Factor) 1.E+00 (0.1) Shear Modulus (MPa)/(Loss Factor) 10 Frequency (Hz) Frequency (Hz) 1.E+01 (1.0) 70 1.E+04 10000 100 1.00E+01 1.00E+06 1.00E+08 1.00E+10 0.1 1.00E+12 July 9, 2013 - Orig ISOLOSS SL-60300 Isoloss SL-60300 1.E+02 1.00E-01 1.00E+04 Reduced Frequency Frequency (Hz) Reduced (Hz) 1000 1.00E-03 1.00E+02 July 9, 2013 - Orig 1.E+03 1.E-01 1.00E-05 10000 (1.0) ISOLOSS SL-50300 Isoloss SL-50300 Shear Modulus (MPa) / (Loss Factor) 40 1.E+03 1.E-01 1.00E-04 Shear Modulus (MPa)/(Loss Factor) 60 50 1.E+04 Frequency (Hz) Frequency (Hz) ShearShear Modulus (MPa)/(Loss Factor) Modulus (MPa) / (Loss Factor) 60 50 10000 1.E+04 (877) EAR-IDEA (327-4332) Rm. 807, 8/F, B Area 40 30 20 10 0 -10 -20°C 10000 1.E+03 1000 1.E+02 100 (1.0) 1.E+01 10 1.E+00 1.00E-04 1.00E-02 1.00E+00 1.00E+02 1.00E+04 1.00E+06 1.00E+08 1.00E+10 1 1.00E+12 Reduced Frequency (Hz) July 9, 2013 - Orig ­­ 7911 Zionsville Road 50 (0.1) 0.1 1.00E+11 Toll-free hotline 60 Reduced Frequency (Hz) Indianapolis, IN 46268 Phone (651) 575-0151 Zhongtianyuan Logistics Center Taohua Rd. Shenzhen, China (P.R.C.) Phone: 86-755-8348-5522 July 9, 2013 - Orig Fax (317) 982-3401 Futian Free Trade Zone Fax: 86-755-8348-5533 ©2014 Aearo Technologies • Printed 9.16 Frequency Frequency(Hz) (Hz) 70 ISOLOSS SL-35300 Isoloss SL-35300 Frequency (Hz) Frequency (Hz) Isoloss SL-20300 ISOLOSS SL-20300 CONFOR™ EG Foams Typical Properties Property CFNT-EGS CF-40EG Density Nominal kg/m3 (lb/ft3) ASTM D3574 83 (5.18) 96.1 (6) Ball Rebound % ASTM D3574 < 1 < 1 Thermal Conductivity – K Value ASTM C518 W/m*K (BTU in/hr ft2 F) .0039 (0.27) .0039 (0.27) Compression Set (%) ASTM D357­­ 22hr @ 22C (72 F), Compressed 50% < 1 < 1 Indentation Force Deflection ASTM D3574 Test B1 Modified 25% Deflection for 12” x 12” x 2” sample 22C (72F) @ 50% Relative Humidity (lbf) 10-17 15-28 Tensile Strength kPa (psi) ASTM D3574 5.1mm/min (20 in/min) 48 (6.7) 53 (7.7) Tear Strength kN/m (lbf/in) ASTM D3574 5.1 mm/min (20 in/min) @ 22C (72F) 0.28 (1.6) 0.32 (1.8) Tg (Peak Loss Modulus), ºC DMA, 10 Hz & 0.3 amplitude, 30% compression -2.5 2.7 Peak Tan Delta @ Temp C (F) DMA, 10 Hz & 0.3 amplitude, 30% compression 1.34 @ 22 C 1.33 @ 26 C Compression Load Deflection ASTM D 3574C Modified* Force @ 10% Compression kPa (psi) 0.83 (0.12) 1.65 (0.24) Force @ 20% Compression kPa (psi) 1.1 (0.16) 1.86 (0.27) Force @ 30% Compression kPa (psi) 1.2 (0.18) 2.07 (0.30) Force @ 40% Compression kPa (psi) 1.5 (0.22) 2.41 (0.35) Force @ 50% Compression kPa (psi) 1.8 (0.26) 3.03 (0.44) Force @ 60% Compression kPa (psi) 2.4 (0.35) 4.21 (0.61) Force @ 70% Compression kPa (psi) 3.9 (0.57) 7.58 (1.1) Force @ 80% Compression kPa (psi) 9.0 (1.3) 21.4 (3.09) CF-42EG CF-45EG CF-47­­EG 96.1 (6) 96.1 (6) 96.1 (6) < 1 < 1
CF42SC1MM
物料型号: - ISODAMP™ C-8000系列 - ISOLOSS™ SL系列 - CONFOR™ EG系列 - CONFOR™ SC系列
器件简介: - 这些产品是用于噪声、冲击和振动控制的高阻尼热塑性和热固性模塑产品。
引脚分配: - 文档中没有提及引脚分配信息,因为这些是材料而非电子元件。
参数特性: - 硬度范围从40到88 Type A Durometer(ISODAMP™ C-8000) - 硬度范围从20到60 Type A Durometer(ISOLOSS™ SL) - 高度合规的冲击和能量吸收泡沫产品(CONFOR™ EG和SC)
功能详解: - 所有产品均符合RoHS标准,JIG-101标准,无卤素,部分产品具有UL 94 V-0阻燃等级。
应用信息: - 用于控制噪声、冲击和振动,适用于多种工业和电子应用。
封装信息: - 文档中没有提及封装信息,因为这些产品是材料而非电子元件。
CF42SC1MM 价格&库存
很抱歉,暂时无法提供与“CF42SC1MM”相匹配的价格&库存,您可以联系我们找货
